[Solved] Bosch Classixx 6 WAA16163 washing machine - does not start, LEDs light up
lechooo93 9480 3
  • #1 17101056
    lechooo93
    Rate: 14
    I have a problem with the Bosch washing machine. Recently, it stopped halfway through the washing cycle, the water was in the washing machine, and the door normally opened. I used to replace the door lock and that was the first thing I checked. After opening the washing machine, it turned out that the lock cable was unfastened. I replaced the lock with a new one, but the Washing and Rinse LEDs are still lit. According to the instructions, it is a door, but I can not get rid of them or start the washing machine in any way.
    I'm counting on your help. :)
    Below I paste the link to the movie, which shows the behavior of the washing machine .... nothing else happens.
    [Film: b8fa87537e] https://filmy.elektroda.pl/20_1520970209.mp4 [/ film: b8fa87537e]
    Regards
  • #2 17101816
    bubu64
    Help: 57
    Rate: 283
    Have you tried to clear the error?
  • #3 17101942
    lechooo93
    Rate: 14
    Yes, but I couldn't find information for this particular model.
    I tried at 6 o'clock -> spin reduction -> 7 o'clock but didn't want to enter anything.
    I also tried to set the program where it stopped and click start for a minute even but nothing happens.
    Before replacing this lock with the setting of Any program, the washing machine took in water, even when the door was open, as I allowed it, it stopped after a while.
    According to me, the washing machine vibrating caused that the cable from the door fell out and the program was interrupted, I just don't know how to reset it
  • #4 18162143
    lechooo93
    Rate: 14
    I replaced the control panel (all white panel with electronics) and it helped. The cost is about PLN 100 for used.
    Thank you for your help and best regards
