Broken Thread Repair: Steering Knuckle Golf 4, Sliders, Calipers, CX80 RC42 Glue & Used Crossover
pio1986 15591 13
Can I safely repair a broken brake caliper carrier thread with glue, or should I replace the part?
No, glue is not the recommended fix here; the safer and more sensible solution is to replace the crossover/steering knuckle or repair the threads properly. One reply says replacing only the crossover is the right option and can be done in about 15–20 minutes [#16308086] Another suggests a proper thread repair instead of glue, using an M9 Helicoil set so the old guides can remain [#16308396] A different option mentioned was making new guides with an M10 thread, but others warned that after drilling there is little wall left and they would not trust such a repair [#16313448][#16313903] One user noted that these screws mainly hold the caliper in place, but the thread repair still should not be a glued workaround [#16313915][#16308042]
  • #1 16307977
    pio1986
    Hello all. Recently, I decided to replace the pads myself and roll the shields because they required it. So I got to work, when I screwed the sliders it turned out that they could not be tightened to the crossover. I stripped everything renewing all calipers and shields and it turned out that there was a broken thread on the switch. Someone advised me to catch them with screw glue. So I did, I bought CX80 RC42 glue. I put everything and these sliders pasted into the crossover, after many yesterday's attempts to brake is ok. But I'm afraid it won't last long and will it be safe?
    Is it possible to buy a used crossover and replace it but it is a lot of work and I need a car because I have 80 km to work.
  • #2 16308042
  • #3 16308045
    piotrekwoj1
    Help: 947
    Rate: 3433
    pio1986 wrote:
    sliders
    Which element are you writing about?
    Moderated By ociz:
    Type FS III terminals. You will see these on whether you will know what's going on.
  • #4 16308086
    ociz
    Help: 1379
    Rate: 3486
    Of course only the crossover is replaced.
    pio1986 wrote:
    but it's a lot of work
    Which you sponsored yourself. For me it is 15-20 minutes, unless the placenta by the way is a little longer.
  • #5 16308134
    milejow
    Help: 1563
    Rate: 5149
    Not necessarily, guides with M10 thread are available - ream, thread and (almost) the original.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #6 16308396
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    Helicoil M9 set and old guides remain.
  • #7 16308431
    patryk44gks
    Help: 11
    Rate: 74
    It is better to mention, I suppose that for golf IV it will not be a big cost or at least you will be sure that the glue will not let go.
    I think my friend was talking about a yoke.
  • #8 16313448
    pio1986
    Hello, today I ordered two the same sliders with M10 thread in a turning plant, on Thursday to collect, cost about 50 PLN, they already had several such orders. On Monday I visited all stores.
  • #10 16313798
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    bandi21 wrote:
    you could buy such a set, of course there are much cheaper sets on the allegro.
    In the event of a fatal accident through these combinations you can sit a little with no conscience.
    Hacks, steering, timing system, bearing bolts or head should not be repaired ;-)
  • #11 16313884
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    You don't know what you're writing about.
  • #12 16313903
    ociz
    Help: 1379
    Rate: 3486
    I would not put my hand to such "repair". After drilling, the M10 has little wall there, and the guides made at the turner are no longer ...
  • #13 16313906
  • #14 16313915
    robokop
    Help: 1763
    Rate: 6372
    Stop it, these "screws" only hold the clamp so that it does not fall out by itself, do not carry any terrible loads. I'm just surprised how you can break it - someone tried to force the askew. I close anyway.
The discussion revolves around a user who encountered a broken thread on the crossover while replacing brake pads and calipers on a Golf IV. They initially used CX80 RC42 glue to secure the sliders, but expressed concerns about the longevity and safety of this repair. Responses varied, with some suggesting that replacing the crossover is the best option, while others mentioned alternatives like using M10 threaded guides or Helicoil inserts for thread repair. The consensus leans towards prioritizing safety over temporary fixes, especially in critical components like steering and braking systems.
