Golf 4: TRV Brake Discs Complaints - Experiences with Wear Over 0.3mm & Strikes When Braking
bula17 5190 15
Why were the brake discs rejected as a complaint after about 10,000 km, and can braking vibration with 0.3 mm wear still be treated as a manufacturing defect?
The complaint was likely rejected because the disc runout/wear was considered an operating effect, not a manufacturing defect, especially after about 10,000 km of use [#16395999][#16396330] Several replies point to checking the hub first: measure hub runout with a dial gauge or a 0.01 sensor before fitting the discs, because the hub itself often causes the disc to start beating [#16398617][#16405827][#16394635] One reply also notes that overheated discs are possible and that the condition of the pads, pistons, and overall braking style should be considered [#16394424] In short, if the hubs are clean and within tolerance but the discs still vibrate, the problem is more likely in the installation or operating conditions than in a hidden factory defect [#16394664][#16395999]
  • #1 16394300
    bula17
    Help: 52
    Rate: 295
    Hello, I installed TRV shields and beats and the opinion of the wholesaler is that it is not known whether to laugh or cry :) Do you have similar experiences ??
    Complaint code: 13RE009905
    The part was purchased on: 25/04/2016
    Complained on: March 30, 2017
    Mileage after installing the parts: 24100km
    Claim reason: It strikes when braking.
    The advertised part was inspected and found:
    1. Abrasive wear over 0.3mm.
    Conclusion
    The supplied brake discs show visible wear of the friction surface
    over 0.3mm. After a mileage of more than approx. 2000 km, the dials lose their parameters
    during the production process in favor of the parameters acquired during operation, "runout
    discs "is caused by operational factors, which is beyond the manufacturer's control.
    Discs burdened with a manufacturing defect would show "beating" during test drive or after
    examining the sensor. The fact that no irregularities were found during the test drive
    confirms that the purchased discs were not burdened with the defect of uneven thickness on
    the circumference of the shields.
    The complaint cannot be accepted
  • #2 16394322
    ociz
    Help: 1379
    Rate: 3486
    I would also dismiss the claim in this case.
  • #3 16394424
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    I also don't understand the author's frustration. Discs possibly overheated. The author does not mention the condition of e.g. brake pads, pistons, and we do not know what style of driving he prefers ...?
  • #4 16394519
    bula17
    Help: 52
    Rate: 295
    Honestly, I do not know how they were operated because I only mounted it and as far as I know, the client's wife drives it, so rather calmly, 3/4 nice pads without any signs of overheating, the clamps work flawlessly under the dust covers, clean. From another wholesaler they say that the trv went on quality and they have a lot of complaints.
  • #5 16394618
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Runout-checked hubs?
  • #6 16394635
    Eidems
    Help: 83
    Rate: 253
    Most hubs beat in such cases. I know a case where the hubs were ok and the discs started to beat after a short time, the complaint was accepted (BMW service).
  • #7 16394664
    bula17
    Help: 52
    Rate: 295
    unfortunately I have no way of checking. The hubs have been cleaned again and the texstar kit fitted, time will tell.
  • #8 16395323
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    I do not fully understand, you advertise shields after a year of operation and mileage of 24kkm?
  • #9 16395455
    bula17
    Help: 52
    Rate: 295
    This is the current mileage and some 10,000 are made on them.
  • #10 16395999
    robokop
    Help: 1763
    Rate: 6372
    Teeth in plaster. The wholesaler is right - the "runout" was acquired as a result of exploitation, which is not covered by the warranty.
  • #11 16396330
    ociz
    Help: 1379
    Rate: 3486
    This is all the more so when after 10 thousand worn 0.3mm, they had to be well angulated.
  • #12 16396555
    domasia
    Help: 12
    Rate: 43
    Current 24,000 km mileage in the Golf IV?
  • #13 16398571
    noga
    Help: 5
    Why were the brake discs replaced at 14,000 km?
  • #14 16398612
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Perhaps there was a curb and there will be a repeat of the entertainment next year. You've got into it.
  • #15 16398617
    noga
    Help: 5
    I suggest a dial gauge and check the hub runout before mounting the discs.
  • #16 16405827
    lookashECL
    Help: 8
    Rate: 60
    The 0.01 sensor for this magnetic stand and you will quickly check if the problem of the curvature of the discs is not caused by the hub itself.
The discussion revolves around complaints regarding TRV brake discs installed on a Golf IV, specifically concerning wear exceeding 0.3mm and a "beating" sensation when braking. The original poster reported that after 24,100 km, the discs showed significant wear, leading to a claim against the wholesaler. Responses from other users suggest that the wear may be due to operational factors rather than manufacturing defects, with some questioning the condition of other components like brake pads and hubs. There are suggestions to check the hub runout and the possibility of overheating as contributing factors. Overall, the consensus leans towards the idea that the wear is a result of normal use rather than a defect in the brake discs themselves.
