[Solved] Beko DIN 5835 dishwasher - error ER 1 ER 3 ER9 - crashed the differential after
szaprpaw 10734 6
  • #1 16308141
    szaprpaw
    A few days ago at night there was a power outage. After the power came back, I restarted the dishwasher. I chose the program and at this point, after pressing START, it broke the differential. The dishwasher did not drain the water completely. Today I buried how to check the error codes that are.
    ER 1 ER 3 ER9 - these are the codes and I have not found their meaning.
    The question is what are these errors and can I try to remove them? Call the service immediately, and the equipment is already a year after the warranty.
    Thanks for your understanding and help. pzdr
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    Leave mistakes for now, look for the reasons for the short circuit.
  • #3 16308377
    szaprpaw
    So where to start best?
    zibi1971
    Help: 262
    Rate: 1120
    You need a meter, start with the heater
  • #5 16309491
    szaprpaw
    Any trusted website in Lublin?
  • #6 16309845
    mamkonto
    Help: 14
    Rate: 108
    I chose the program - and at that moment after pressing START she broke the differential.
    Throwing out the differential is not a short circuit but a voltage leak, very often due to flooding (moisture), although damage to e.g. a heater or a pump cannot be excluded ... Choose a sponge with water from the dishwasher under the filter. Disconnect from the voltage, slide it out, turn it over on your back, remove the bottom case, unhook the float from it. Check if there is water or traces of water in the tray, if there are traces, wet or even dry patches, look for something is flooded, check the connectors, electronics ... If you find dry ...
  • #7 18120659
    szaprpaw
    The problem was with the heater.
The discussion revolves around a Beko DIN 5835 dishwasher that experienced issues following a power outage, leading to error codes ER 1, ER 3, and ER 9. The user reported that the dishwasher failed to drain completely and caused a differential to trip. Responses suggest investigating potential causes of a short circuit, particularly focusing on the heater and checking for moisture or flooding within the unit. It was noted that the differential tripping is often due to a voltage leak rather than a direct short circuit. The user later confirmed that the problem was indeed related to the heater.
