[Solved] The BEKO DIN28330 dishwasher displays error E01, does anyone know what it means?
Czempiniak 167538 2
  • #1 17205380
    Czempiniak
    Rate: 64
    Hello, the BEKO dishwasher initially did not pump out the water, after cleaning the filters and the hose pumped out the water, but now it displays error E01, roars and does not want to turn on. Please help.
  • #3 17231041
    Czempiniak
    Rate: 64
    The solution to the problem turned out to be very simple. Unfortunately, it was necessary to remove the entire dishwasher from the built-in, unscrew the hoses and tilt the dishwasher on its back at an angle of 45 degrees and pour out all the water from it. The dishwasher stood for 15 minutes and then after reconnecting it worked fine, the error disappeared.
