Beko DIN5834 - how to activate the service mode in the dishwasher?
edzio4 24306 13
How do I activate the service (diagnostic) mode on a Beko DIN5834 dishwasher?
Turn the dishwasher off, then press and hold the washing start button (PLAY/PAUSE) and the POWER switch at the same time for about 10 seconds; the diagnostic mode should start and show the error list (ER1, etc.) [#18201006]
  • #1 16351139
    edzio4
    Rate: 39
    Please specify how to activate the service mode in the Beko 5834 dishwasher?
    Thanks and regards.
  • #2 16352331
    Super_technik
    Help: 9
    Rate: 48
    Write what you want to achieve.
  • #3 16356854
    edzio4
    Rate: 39
    I would like to activate the service mode in the Beko 5834 to check what is wrong with it, because I cannot start it.
    best regards
  • #4 16356912
    Super_technik
    Help: 9
    Rate: 48
    Without service mode, you can't write what's going on?
    There are only a few key faults in the dishwasher and they can be diagnosed without the service mode.
  • Dishwasher fills but program timer does not advance
    #5 16358285
    edzio4
    Rate: 39
    Hello, thank you for your answers and I am asking for more valuable tips regarding my beko 5834 dishwasher, I will describe what is happening; When starting any program, whether for 30 minutes or 45 minutes, the dishwasher draws water, but the water is at the bottom of the dishwasher and the program clock does not decrease on the selected program. After the reset, it drains the water. Could it be a pump. I am asking for help. Regards
  • #6 16365250
    edzio4
    Rate: 39
    Hello, super technician, why don't you write your advice was valuable and helpful for me. Please give me some tips for my beko 5834 dishwasher.
  • #7 16367038
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    Probably a damaged wash pump or starting capacitor if there is one. It is also worth checking the heater and whether the voltage to the pump comes when the dishwasher stops taking water.
  • #8 16367555
    edzio4
    Rate: 39
    Hello, thank you very much for your answer and tips, I would like to know if the things you mentioned about the Beko 5834 dishwasher are profitable for me to repair or buy a new one. I am 5 years old Beko dishwasher and it broke for the third time. Best regards.
  • #9 16368781
    h jaworski
    Help: 466
    Rate: 717
    You see, you want a description of the service mode, and you do not give the exact model of the dishwasher because 5834, if it's a good designation, it is only partial, probably a few letters are missing (Beko DIN5834). Is the repair worth it? You would have to diagnose what is damaged, there is no diagnosis, it is impossible to say about the costs.
  • #10 18201006
    flow3
    Rate: 23
    The mode in which the dishwasher performs diagnostics and displays errors is enabled as follows:
    - turn off the dishwasher,
    - press and hold the washing start button (PLAY / PAUSE) and the (POWER) switch at the same time
    - after about 10s the list of errors (ER1 ....) will appear
  • #11 18202169
    qwazarpl
    Help: 37
    Rate: 270
    I can bet that the washing pump is not working and humming after the water is drawn.
    It should be audible
  • #12 18345935
    qwazarpl
    Help: 37
    Rate: 270
    Check the washer pump for blockage.
  • #13 18528005
    DZWILU88
    Rate: 94
    Can someone post an explanation of the errors.
  • Service mode runs P1–P9 with Er3 at end
    #14 21148134
    piotr_krak
    Help: 65
    Rate: 57
    >>18201006 .
    Beko DIN5833 dishwasher
    Service mode fired up and does a test from P1 to P9. Is there a manual somewhere describing what it does at any given P? I get an Er3 error at the end. The heater is ok, about 29 ohm
    The NTC sensor is also about 30 kΩ or 60 kΩ, I can't remember anymore. The only noticeable moment is the heater has voltage and it disconnects the thermostat at the heater, and I guess it's the electronic module and thyristor that should disconnect the heater? Does anyone even have a manual for this model?
The discussion revolves around activating the service mode in the Beko DIN5834 dishwasher to diagnose issues preventing it from starting. Users describe symptoms such as water accumulation at the bottom and the program timer not decreasing. Suggestions for troubleshooting include checking the wash pump, starting capacitor, and heater functionality. A specific method to enter service mode is provided: turn off the dishwasher, then press and hold the washing start button and power switch simultaneously for about 10 seconds to display error codes. Concerns about the cost-effectiveness of repairs versus purchasing a new unit are also raised, given the dishwasher's recurring issues over five years.
