Diagnostics & Checks Before Replacing Beko DIN 5832 (95829): Addressing E1, H6, H3 Errors
Mirosław121 12372 6
  • #1 16900149
    Mirosław121
    Rate: 10
    Please let me know what else I can check before replacing the dishwasher. It started with no drainage, it showed error E1. I checked all hoses, drainage pump - they are correct. When I turn on the dishwasher I do not want to start, after a few minutes error E1 appears. If I enter the service menu, an error H6 appears, less often H3 - the water supply is definitely functional. Is it the programmer's fault?
  • #2 16901499
    machnicki.krzysztof
    Help: 12
    Rate: 79
    Have you checked the drain pump? pump starts when a new program starts?
  • #3 16902075
    Mirosław121
    Rate: 10
    Yes, I checked the drain pump. Works properly.
  • #4 16902119
    machnicki.krzysztof
    Help: 12
    Rate: 79
    So the water is pumping correctly? In that case, check the flow meter
  • #5 16902148
    Mirosław121
    Rate: 10
    I removed the drain pump from the dishwasher and plugged it in, it works, but when I install it in the dishwasher, no program starts at all. I turn on, close the door and nothing, and after a few minutes an error E1 appears.
  • #6 16902489
    machnicki.krzysztof
    Help: 12
    Rate: 79
    Error e1, if I'm not mistaken, means leakage, water in the bowl under the dishwasher. That is, the flood sensor included. But in this case the drain pump should work all the time. Check the flood sensor. If it is Ok, check the door lock if it does not turn on. If all this is OK, give accurate pictures of the steering module.
  • #7 16912751
    Mirosław121
    Rate: 10
    Problem solved.
    It turned out that the cables on the door connecting the dishwasher broke / broke. The exchange removed errors. The dishwasher works perfectly. There was no broken pump / clogged hose etc.
The discussion revolves around troubleshooting a Beko DIN 5832 dishwasher exhibiting E1, H6, and H3 error codes. The user initially reported issues with drainage and confirmed that the drain pump and hoses were functioning correctly. Subsequent suggestions included checking the flow meter and flood sensor, as E1 typically indicates a leakage detected by the flood sensor. Ultimately, the problem was resolved by identifying broken cables on the door, which were preventing the dishwasher from starting. After repairing the cables, the dishwasher operated normally without further errors.
