Zwarcie Renault Grand Espace 4 3.0 DCI: Car Won't Start, Red Stop Indicator - Short Circuit?
Kruszewski2 5733 6
  • #1 17292023
    Kruszewski2
    Hello. I have a Renault Grand Epsace 4 3.0 dci and for some time the car won't start. When the ignition is turned on, the red indicator lights up and writes stop. I suspect that it is short circuiting somewhere, please help. Thank you in advance Zwarcie Renault Grand Espace 4 3.0 DCI: Car Won't Start, Red Stop Indicator - Short Circuit?1529753018...259224.jpg (2.5 MB)You must be logged in to download this attachment.
  • #2 17292039
    coperfild
    Help: 292
    Rate: 1700
    Something with an immobilizer, maybe a card.
  • #3 17292050
    Kruszewski2
    And what exactly could be with the immobilizer? Need to decode it?
  • #4 17292057
    coperfild
    Help: 292
    Rate: 1700
    Most often it is the fault of the card, maybe there is something wrong with it, e.g. the coil. There is a second card?
  • #5 17292070
    Kruszewski2
    I don't have a second card
  • #6 17293875
    genek1000
    Help: 290
    Rate: 1058
    If it were a card, the ignition would not turn on.
    The permanently lit IMO diode signals a problem with "getting along" between the engine controller and the cabin controller (UCH) - no power to the first one or the CAN line is damaged
  • #7 17294025
    milejow
    Help: 1564
    Rate: 5155
    Until I went to Lagunki to check the blank card because I was to write that you were wrong :D
    Exactly, the blinking is a missed card, the steady light is the lack of getting along with the ECM and UCH.
    Działalność własna
    Mętów 99, Lublin, 20-388
The discussion revolves around a Renault Grand Espace 4 3.0 DCI that fails to start, indicated by a red "stop" light on the dashboard. Initial suggestions point to a potential issue with the immobilizer, specifically the key card, which may be malfunctioning. However, further insights suggest that if the ignition is on, the card is likely not the problem. Instead, the persistent illumination of the immobilizer (IMO) diode indicates a communication failure between the engine control module (ECM) and the body control module (UCH), possibly due to a power issue or a damaged CAN line.
