Smart GPS SG732: Correct Port GPS & GPS Speed Settings for MapaMap Configuration
Black4Killer 9003 3
  • #1 16313488
    Black4Killer
    Hello to the forum members what are the correct settings of Smart GPS SG732 under Port GPS and GPS Speed in MapaMap?
  • #2 16313638
    japycz321
    Help: 92
    Rate: 141
    you can check it with the SirfTech application.
    • SirfTech.exe (186 KB) You must be logged in to download this attachment.
  • #3 16315415
    _Olivka
    Help: 81
    Rate: 158
    Set to:
    ----- port COM2
    Speed ------- 9600
    You can set the same as MapaMap shows.
  • #4 16349852
    Black4Killer
    Thank you all for your help :) set the port to: COM2 and speed: 9600 works.
