Navigon 70/71plus: No GPS Signal in iGO Primo - Automapa Compatibility, NMEA Protocol, Sys.txt
janko23 5865 4
  • #1 16486899
    janko23
    Rate: 12
    Hello, strange problem. After installing the automapa in compatibility mode with this navigon, the automapa works and the gps signal is on. However, after installing the Igo Primo, unfortunately, it does not find the GPS signal. GPS device found while searching for a signal and that's it. The entry in sys.txt is:
    [gps]
    protocol = "NMEA"
    baud = 9600
    port = 2
    ; enable_advanced = 1
    ; disable_advanced = 0
    I've tried different ports and speeds. Most likely the navigon is blocking the port, that's it. I tried to run the spliter port (several versions), unfortunately it starts but without any configuration. If someone would explain to me and help me, I would be grateful
  • #2 16487017
    jajacekpl
    Help: 65
    Rate: 268
    See the thread "Navigon IGo Primo no GPS" - there you have a link to solve the problem
  • #3 16487535
    janko23
    Rate: 12
    I saw, in my case, unfortunately, I don't know why it didn't work.
  • #4 16690437
    vaczak
    Help: 50
    Rate: 141
    [gps]
    protocol = "NMEA"
    baud = 9600
    port = 2
    Hello!
    In that case, the port, the auto baud is appropriate.
    baud = auto
    port = auto
  • #5 16690616
    janko23
    Rate: 12
    Unfortunately, in this case it did not help. The equipment was unrepaired. Regards
