Prestigio Multipad 2 7.0 - Does not turn on and do not want to enter the reset
Tom2666 11421 8
  • PMP5670C remains stuck despite reset and firmware attempts
    #1 16319872
    Tom2666
    Help: 7
    Rate: 11
    Hello, I have a tablet as in topic, model PMP5670C. The tablet jams at the start in a photo-like place Prestigio Multipad 2 7.0 - Does not turn on and do not want to enter the reset and here the loading circle can go on and on. Immediately I write that I tried to reset by running the Volume + button with the Power button and each time it starts the same way, there is no option where Android should be shown with the choice of reset option. I also downloaded the firmware from the manufacturer's website, formatted the Micro SD card with the FAT 32 file system and copied the Update.zip, factory_update_param.aml, uImage_recovery files to it and boot the tablet as before with the inserted card and nothing else still stands in the same place. I will add that I tried many combinations with backup buttons, I kept both for a long time, I released power faster while holding Volum + etc. The tablet can only be turned off after a while by holding the Power button. Maybe someone had a similar problem and solved it or has some ideas, so thank you for your help, best regards
    gradek83
    Help: 930
    Rate: 2104
    Unless I'm mistaken the tablet is on the amlogic chipset you do the micro SD card through the program Amlogic SD card Maker .
  • #3 16320539
    Tom2666
    Help: 7
    Rate: 11
    No, I just copied the files and put them on the card, but I check right now, but why does this robot not move, where should the choice be?
    Added after 8 [minutes]:
    I run this program and when I want to indicate something as an image I can see nothing, I will add a photo which I have downloaded files after unpacking Prestigio Multipad 2 7.0 - Does not turn on and do not want to enter the reset
    gradek83
    Help: 930
    Rate: 2104
    From the site producer's you downloaded the UPDATE update file, if you follow the instructions, the update should start.
    In the attachment you have the BIN bootloader file, load it with this program according to instruction just don't confuse the drive letter of the micro SD card with the system disk.
    Or check if you can get in recovery mode and clear the cache and restart as it will do nothing then wipe data factory reset
    • u-boot-orig.bin (541.7 KB) You must be logged in to download this attachment.
  • #5 16320726
    Tom2666
    Help: 7
    Rate: 11
    So, I downloaded from this site the firmware compatible with the tablet model, i.e. with the C terminal after 5670, i.e. run Amlogic SDcard Maker, select the format for FAT 32 and in Browse select the BIN bootloader file? , so I did and showed that the card is bootable and I upload these downloaded files from the manufacturer's website to the card, insert it into the tablet and turn it on holding Volume + with Power and still booting up to the same moment
    gradek83
    Help: 930
    Rate: 2104
    Tom2666 wrote:
    and continues to run to the same moment
    There I added an earlier post how to enter recovery mode check.
    Alternatively, turn off the tablet, completely insert the micro SD card and press the reset button, if this tablet has after the reset, it should move after a while, if not I will give you different bearing, but it's on PW
  • #7 16321939
    Tom2666
    Help: 7
    Rate: 11
    Well, the problem is that this recovery mode does not want to start, I will add that I have a second tablet from this company a little newer and everything turns on on it, from this micro sd card and holding volume + power. I wonder if the volume button works? but when I press volume - with power then it does not start, and with volume + starts but not starting to recovery and only to the place where I wrote in the first post. Unfortunately, the tablet does not have a reset button, everything worked in it before the failure, it just lay a bit untouchable and is so far so far, thanks for your willingness to help :)
  • #8 16322059
    gradek83
    Help: 930
    Rate: 2104
    Check if you can initialize the tablet to bootloader.
    1) Turn off the tablet by long pressing the POWER button
    2) Connect the USB cable to the USB2 not USB3 socket and plug the cable into the tablet should turn on and show that the battery is charging
    3) Press and hold the POWER button (Tablet will turn off)
    4) Now press the Volume + and POWER buttons simultaneously and hold
    5) You should hear the sound of the device being connected on your PC and new equipment detected
    6) Drivers are attached
    Then it's just as I wrote you in the message.
    Additional information check:
    Turn off the tablet press VOLUME- and holding it press power as soon as something appears on the screen release the POWER button and keep holding VOLUME- it takes a while but Recovery mode should appear. if it appears, give it WIPE CACHE PARTITION and REBOOT SYSTEM NOW, if it doesn't work then give WIPE DATA / FACTORY RESET
    • AmlogicusbBurningdriver.rar (322.12 KB) You must be logged in to download this attachment.
  • #9 16329441
    Tom2666
    Help: 7
    Rate: 11
    For everyone who has the same problem with this tablet, I describe the order of actions that have fixed the problem with the great help of the excellent gradek83 forum member here, whom I once again thank you for quick answers and all the help :)
    We do everything in clean boot mode with disabled driver signatures enforcing at Windows 8 and up https://spece.it/windows-serwer-artykuly/windows-10-i-installing-sterownikow-without signature- digital signature
    So we start by downloading Firmware from the manufacturer's website http://www.prestigio.pl/catalogue/Archive_pro..._PRO_DUO_7.0/PMP5670C_WH_DUO#/product-support,
    then from here
    https://mega.nz/#!LtczXabI!DYRYSvzHES0yT9Xqj4q19-bfbsdVQONzYK2kkY3ZRrs download the files and after unpacking we get:
    1) pmp5670c_duo_20130823_usb_burn_v1.0.05.zip
    2) USB-Burning-tool-v1.6.28_2.rar
    3) d7002-usb-burn-fix-boot-issue.zip
    Extract the file No. 2 and entering the folder as the administrator run the ImageBurnTool.exe file, in the upper left corner click File and select Import upgrade file from the menu and select the file pmp5670c_duo_20130823_usb_burn_v1.0.05.zip and wait for it to load. Then click File again on Import config file and in the directory ... pmp5670c \ USB-Burning-tool-v1.6.28_2 \ tmp \ PMP5670C_DUO-usb-burn, select the file config_progress.xml, connect the tablet via USB and should be detected in one from ports, when this does not happen we enter the device manager and check whether it is visible in Other devices. If it is not there, it is probably detected in the serial bus controllers as USB which will not help us, so when the tablet is connected via a USB cable (the device is turned off at this time), click holding the Volume button - together with Power and the device should show us in other devices under the name M3CHIP and here we click on the right name and select the driver update by selecting the manual indication and select the folder downloaded from the manufacturer's pmp5670c website and install the drivers after which the tablet should load in one of the ports the rest and this can be seen in this https video : //www.youtube.com/watch? v = hDph6AuqLao & feature = youtu.be & t = 1078
The discussion revolves around troubleshooting the Prestigio Multipad 2 7.0 (model PMP5670C), which fails to boot past the initial logo screen. The user attempted to reset the device using the Volume + and Power buttons but could not access recovery mode. Suggestions included using the Amlogic SD Card Maker to create a bootable micro SD card with the correct firmware files, ensuring the correct drive letter is selected, and trying various button combinations to enter recovery mode. Additional advice involved checking the tablet's bootloader and using a USB connection to facilitate recovery. Ultimately, a successful method was shared, detailing the steps to download the necessary firmware and tools, and execute the recovery process while disabling driver signature enforcement on Windows.
