Modecom FreeTab 9701 IPS Won't Turn On: Stuck at MODECOM Logo, Need Data Recovery
Wimp 6453 9
How can I get a Modecom FreeTab 9701 IPS tablet past the MODECOM logo and recover the files stored in its internal memory?
Turn the tablet off, then hold Power + Volume Down for a few seconds to open the Recovery menu; simply entering Recovery should not erase your files [#16880767][#16880773] If you get into Recovery, look for any backup option, but if USB debugging and root were never enabled, a computer-side backup is probably not possible [#16880868]
  • #1 16880746
    Wimp
    Rate: 9
    Hello, as in the Theme, I have this tablet, but I load until the red word MODECOM, and it stands there, I want to recover the data from this tablet that is on its internal disk.
    I am asking for help, thank you in advance and best regards :)
  • #2 16880767
  • #3 16880770
    Wimp
    Rate: 9
    But won't that erase all my files in Drive?
  • #4 16880773
  • #5 16880782
    Wimp
    Rate: 9
    But I'm trying, nothing happens, what should I do then?
    Managed to! I went in recovery, what next?
  • #6 16880804
  • #8 16880868
    gradek83
    Help: 930
    Rate: 2104
    Maybe you can do it backups what you have left, but if you didn't have rota or USB debugging turned on it's probably none of it. On this type of data carriers, if I can call it that, it is better not to keep important data or configure it to at least synchronize the google account and make automatic copies to the cloud.
  • #9 16880877
    Wimp
    Rate: 9
    I don't know if USB debugging is enabled on the tablet, but root was not there. will you write me how to make this backup? thank you in advance for your help :)
    A friend also said that somehow it is possible to connect an external drive to him and rip everything, but I do not know if it is possible, and I do not know how :)
  • #10 16885840
    Wimp
    Rate: 9
    I have a way out of this situation? please reply quickly, thank you in advance :)
The Modecom FreeTab 9701 IPS tablet is experiencing a boot issue, getting stuck at the MODECOM logo. Users suggest entering the Recovery menu by holding the power and volume down buttons simultaneously, which does not erase data. Once in Recovery, further steps are needed to recover data. Concerns about data loss arise, especially if USB debugging was not enabled or if the device was not rooted. Suggestions include checking Android forums for specific recovery instructions and considering external drive connections for data extraction.
