LTE T-Mobile: Huawei B315s-22 Router & 15dBi MIMO Antenna - Speed Comparison 800MHz vs 1800MHz
ZjemCiKaszke 3495 4
  • #1 16320861
    ZjemCiKaszke
    I have a Huawei B315s-22 router and such an antenna http://allegro.pl/mocna-antena-lte-4g-mimo-15dbi-do-huawei-b315-10m-i5260062988.html. To the city I have maybe 2/3 kilometers, transmitters are relatively close. The antenna is currently exposed to the roof and the signal should be very good. The speed is not bad on the LTEWatch program shows when downloading from Steam 15/25 mb / s at 800MHz but on the internet I can find the results of people who, despite the much worse conditions have 2/3 times faster internet. The terrain is flat on the road there are only houses so there should be no interference. I will add that when I change the frequency to 1800MHz, the speed drops to below 10mb / s but the readings on LTEWatch are much better. If anyone has any idea what might be the reason, please help. I know it's not bad but it could be so much better. 1st picture is 800MHz 2nd picture 1800MHz as you can see the difference in speed is huge even though the range is theoretically better. The antenna is arranged as preferably as possible.
    LTE T-Mobile: Huawei B315s-22 Router & 15dBi MIMO Antenna - Speed Comparison 800MHz vs 1800MHz LTE T-Mobile: Huawei B315s-22 Router & 15dBi MIMO Antenna - Speed Comparison 800MHz vs 1800MHz
  • #2 16320998
    matek451
    Help: 4352
    Rate: 5808
    Show screen with LTE1800. You bought the Dual LTE antenna at 1800MHz and you write that it improves the LTE1800 signal parameters, i.e. it works properly. The low speeds are due to the overload on the LTE1800 NetWorks BTS that you use in T-mobile. But this is already becoming the 'norm', the network that Orange customers are slowly using is also kneeling down. On LTE800 you connect to LTE800 T-mobile Morska 54/56 BTS, the antenna does not work at 800MHz, it only transfers the signal to the outside. LTE1800Networks also works on this BTs and so probably LTE-A but you chose router B315 without aggregation instead of MF286. You have two outputs, you use LTE1800 on Cybertecha or LTE800 T-mobile without antenna or you buy 2xATK-10 / 800-980, ATK-20. There is no guarantee that the LTE800 speeds will soar up. Two reasons, the first one, we don't know if T-mobile uses 10MHz in MIMO or only 5MHz on this BTS. It depends on the equipment on BTS. Secondly, we don't know the load on this BTS. Don't be fooled by the performance of others, LTE speeds in mobile depend on many factors. For LTE1800 connection with LTE1800NetWorks BTS on the license of Orange, Łużycka 25a. Have you tried setting your Cybertech antenna to another less loaded BTS LTE1800Networks? Where are you from?
  • #3 16321029
    ZjemCiKaszke
    The picture went. I'm not saying I'm not happy but I expected much better results due to the distance of these transmitters. Antennas rather I will not change just a pity that 1800MHz works so slowly.
    Added after 6 [minutes]:
    Niekłonice near Koszalin we set the antenna based on data from LTEWatch at these frequencies. We set it based on the speed at these frequencies. At 1800MHz there was nowhere comparable speed to what we have at 800MHz
    Added after 4 [minutes]:
    This is how you say overload because at night even without an antenna the internet worked very fast.
  • #4 16321752
    matek451
    Help: 4352
    Rate: 5808
    Set the antenna in turn on the LTE1800networks Szczecińska 59A, BTS-siańska8, suburban 49 BTS-y and check the speed and load. LTE800 T-Mobile and probably aggregation of LTE-A bands also work on the latter.
  • #5 16322089
    ZjemCiKaszke
    It's like you say the network is loaded at 2:30 as I switched to 1800MHz, the download was 40mbps. The antenna is screwed to the chimney at this point and I will see what can be done tomorrow. We did tests in all directions on both frequencies at 17:00 on Friday, I think it will be the same despite everything.
