Ursus C330 1983 Black Smoke Issue: Cylinder Head Pistons, Injector Tips & Injection Pump
piotrek_brt 4143 6
  • #1 16324424
    piotrek_brt
    Rate: 78
    Hello, I have a Ursus c330, after replacing the pistons of the cylinder head sleeve and the injector tips, the tractor still smokes black, it may be the fault of the injection pump ????
  • #2 16324457
    bearq
    Help: 414
    Rate: 1612
    The pump and injectors are the basic problems of smoking
  • #3 16324472
    1megan
    Rate: 40
    And the heads were made? Maybe leaking valves could be the cause of smoke
  • #4 16324492
    piotrek_brt
    Rate: 78
    the head is a new keyboard too
  • #5 16324503
    1megan
    Rate: 40
    And the ignition on the pump is set?
  • #6 16325094
    piotrek_brt
    Rate: 78
    Ignition is set
  • #7 16325416
    1megan
    Rate: 40
    And the air filter is obstructed? When he gets little air, he will smoke black.
The discussion revolves around a Ursus C330 tractor experiencing persistent black smoke issues after the replacement of the cylinder head pistons and injector tips. Participants suggest that the injection pump and injectors are likely culprits for the smoke. Additionally, they inquire about the condition of the cylinder head and the possibility of leaking valves. The author confirms that the cylinder head is new and that the ignition on the pump is correctly set. Another suggestion includes checking the air filter for obstructions, as insufficient air intake can also lead to black smoke emissions.
