Fiat Ducato 3.0 160HP 2008: Black Smoke, Radiator & Throttle EGR Issues, Turbine Concerns
toro07 13557 8
  • #1 16453704
    toro07
    I have a problem with Ducato 3.0 160 horses from 2008, namely, the car has always smoked black, after a visit to the mechanic cleaning the radiator throttle Egr the master said that this type is so! The car normally drives the power around. asphalt burns more and sheds a thin pear wire on the turbine.
    Please tell me what the problem is. Thanks
  • #2 16454437
    Gunslinger
    Level 30  
    Help: 114
    Rate: 461
    As for the cable, I do not know, but the rest of the symptoms are pouring injections. It fit to check them on the machine.
  • #4 16454595
    bucek21
    Help: 14
    Rate: 86
    Smoking black would put more pressure on the intake manifold too low.
    Check for leaks between the turbocharger, intercooler and intake.
    As for the pouring injectors, do not listen to it. The pouring injector will kick in gray because it will not burn fuel.
    I suggest you start with simple things.
    Computer diagnostics
    Logs
    Boost pressure.
  • #5 16455688
    toro07
    The mechanic actually mentioned something but the vacuum in the collector was replaced by a sensor etc.
  • #6 17588737
    Euro system trans
    Hello, how did the case with kicking end in this case
  • #7 18080947
    ewa popis
    hello could you write what was the reason for this smoking in black
  • #8 18080965
    toro07
    Unfortunately, it was not possible to diagnose what is the reason for smoking.
  • Suggest checking injectors and turbo for black smoke
    #9 20061589
    anet870
    Help: 67
    Rate: 248
    Has the problem been resolved?
    For me, the ducato started to smoke black, and with time more and more. The map was made right after the purchase and it was fine for a few years. He is strong all the time, he is pushing forward like crazy. The intake is tight and the values of the injectors and supercharging are normal. EGR functional. I will start to blindly tug the injectors and check the turbo later ... If you already know what to do, help me, I will have less work and everyone more health because the vehicle will be ecological :) Ducato 2.3 130hp
The discussion revolves around a 2008 Fiat Ducato 3.0 with a 160HP engine experiencing persistent black smoke emissions. The owner reports that after a mechanic's intervention involving the cleaning of the radiator, throttle, and EGR, the issue remains unresolved. Responses suggest potential causes including faulty injectors, flow meter issues, low intake manifold pressure, and possible leaks between the turbocharger, intercooler, and intake. Recommendations include performing computer diagnostics, checking boost pressure, and inspecting the injectors and turbocharger. Another user shares a similar experience with a Ducato 2.3 130HP, indicating a growing black smoke issue despite previous satisfactory performance.
