Turn Off Airplane Mode on Lenovo T430s Laptop: WiFi Card or Software Issue?
major697 9900 7
  • #1 16325923
    major697
    Hi, I have a laptop "Lenovo T430s" and there is such a problem with it, it is impossible to turn off the airplane mode. Exactly like in this video:
    Airplane Mode Not Turning Off Fixed Windows 10! 2016
    I searched almost all google and the system is completely built from scratch. Reinstalling drivers for WIFi does not help (because it is about turning on WiFi, you cannot turn on wireless transmission when airplane mode is on). Do you know if such a problem may be on the side of the WiFi card and not the software itself?
  • #2 16325969
    nici
    Help: 266
    Rate: 979
    ACPI drivers installed?
  • #3 16326001
    major697
    @nici Yes, I installed from this site: link but nothing helped.
  • #4 16326034
    nici
    Help: 266
    Rate: 979
    Ehh this W10. I had the same, but with the matrix backlight. Only one update in a row fixed it ...
  • #5 16326050
    major697
    @nici I downloaded Ubuntu and Linux Mint on a USB flash drive and I ran the same problem, which is rather a hardware fault, not a system fault.
  • #6 16326064
    nici
    Help: 266
    Rate: 979
    And you see, you didn't write it, and that changes things.
    The computer doesn't have some kind of switch or combination of Fn + XX?
    In my Lenovo I have Fn + F7, e.g.
  • #7 16326229
    kiko80
    Help: 67
    Rate: 163
    You tried to uninstall power manager or whatever your name is, or the Fn + F5 combination
  • #8 16326682
    major697
    Yes, there is a switch. It turned out that the switch tape was slightly pulled out, it is already working ;)
    If someone is looking, here is the documentation pdf .
The discussion revolves around a Lenovo T430s laptop experiencing an issue where airplane mode cannot be turned off, preventing WiFi activation. Initial troubleshooting included checking ACPI drivers and reinstalling WiFi drivers, but these did not resolve the issue. Users suggested potential hardware faults, as the problem persisted even when testing with Linux distributions. A key point raised was the possibility of a physical switch or function key combination (e.g., Fn + F7) being involved. Ultimately, the author discovered that a switch tape was slightly pulled out, which, once fixed, restored functionality.
