Acer Nitro 5 Windows 10: Can't Deactivate Airplane Mode - No Internet, WiFi Connectivity Issues
Kwasiu6 6675 4
  • #1 17217725
    Kwasiu6
    I have an Acer Nitro 5 with Windows 10. Two days was all fine. Today I was surprised by the fact that I lost connectivity to wifi. I entered the panel by the clock and it showed available networks, including mine, to which I was connected, but there was no internet access. To my surprise, airplane mode was also turned on. I clicked on the icon to turn it off, but it failed. I went into the settings and tried to turn it off there, but the slider moved back to the right to the on position when I moved it to the left. How to turn off this crap? I only have a wifi button on the keyboard, which does not go hand in hand with the function key anyway, and there is no separate slider on the housing.
    Cheers
  • #2 17217772
  • #3 17217820
    Kwasiu6
    If it were that simple, I wouldn't ask anyone for advice ...
  • #4 17218027
    makosuu
    Help: 369
    Rate: 370
    And you clicked restart? Because in Windows 10 it is quick to start up and if you press close without holding shift, it will actually be more of a hibernation.
  • #5 17218455
    Kwasiu6
    I reset and closed normally and nothing helped. I also tried with shift and nothing
