Dell Inspiron 15 Laptop: Sound Playing Through Speakers Instead of Headphones
Minsche 9306 6
  • #1 16326683
    Minsche
    I have a problem with the headphones, I mean specifically that when I connect the headphones, the sound comes from the laptop speakers.
    The headphones are good because on another laptop they work, the headphone input is also working, I connected the speaker by the jack and some settings popped up (big headphone or headphones or speaker) I guess it was written in the loudspeaker. The thing is that now I do not have this speaker with me and I'm abroad and when I put on these headphones it does not even show me these settings as if they did not read these headphones at all. You know where I could find this setting because I'm 80% convinced that it is enough to change there and it will be after the case. The input is microphone / headphone. Or give me another idea how I could do it
    My laptop is the Dell inspiron System windows 10
  • #2 16326799
    sosarek
    Help: 9320
    Rate: 15532
    Minsche wrote:
    My laptop is Dell inspiron
    The exact model, the same headphones.
    Z
    Pka, Poznań, 60-850
  • #3 16326809
    Minsche
    Dell inspiron 15 5568, LG headphones are probably cell phones are some with a microphone
  • #4 16326822
    sosarek
    Help: 9320
    Rate: 15532
    Minsche wrote:
    LG earphones are probably cell phones are some with a microphone
    Well, that can be the reason.
    Z
    Pka, Poznań, 60-850
  • #5 16326833
    Minsche
    And you do not know where the jerk's settings are? when I connected the loudspeaker, it made me choose what is connected and I do not know if sometimes I did not change this trash, because I think these headphones worked on my laptop before
  • #6 16326843
    sosarek
    Help: 9320
    Rate: 15532
    If the device is not detected correctly (I suspect that the headphone plug has 4 fields), the settings will not give you anything.
    What to change the settings - Realtek Panel (on the taskbar next to the watch).
    Z
    Pka, Poznań, 60-850
  • #7 16326859
    Minsche
    What can I do?
The user is experiencing an issue with their Dell Inspiron 15 5568 laptop where sound is playing through the laptop speakers instead of the connected LG headphones. The headphones function correctly on another laptop, indicating that the problem lies with the Dell device. The user recalls that when connecting a speaker previously, a settings menu appeared allowing them to select the connected device type, but this option is not available now. A suggestion was made to check the Realtek audio settings on the taskbar, as improper detection of the headphone plug could prevent the settings from appearing. The user is seeking guidance on how to access these settings or resolve the issue without the previously connected speaker.
