daf xf 105 2011 manual gearbox knocks after replacing the clutch
DEVIL 26 8145 17
Why does a DAF XF 105 manual gearbox rattle after a clutch replacement, especially on a cold engine and when the clutch pedal is released?
Such knocking is most likely gearbox backlash, which is a common phenomenon; the fact that it stops when you depress the clutch points more to the gearbox/input side than to the engine itself [#16396582] Another thing to check is the clutch disc specification, because one reply noted that a Sachs disc may have the wrong damper setup and should be a double-shock-absorber type rather than a single one [#16382553]
  • #1 16331063
    DEVIL 26
    Namely, after replacing the clutch after a night, I start and hear a clatter from around the gearbox. A rattling noise occurs when the clutch pedal is depressed
    it stops, I let go of the sound and it knocks for about 10-15 minutes and it stops every morning. Maybe someone had such a case or a similar one ????
  • #2 16342163
    hubert04
    Help: 60
    Rate: 408
    And if you play with your halves, what happens?
  • #3 16344682
    DEVIL 26
    Well, the halves also do not fly for these 15 minutes
    Added after 5 [minutes]:
    and this knocking is more of the selector
  • #4 16345128
    j_a_c
    Help: 7
    Rate: 47
    You've probably installed a cheap Hammer clutch or something like that, cheap discs have poor vibration dampers. I had it more than once after replacing the disc with a real problem, it stopped, in one case the guy said that he did not mind the shafts fell out after a year.
  • #5 16379649
    DEVIL 26
    I installed a Sachs clutch, they said that they were one of the best. I will add that it is complete.
  • #6 16382384
    krisbrumm
    DAF Trucks specialist
    Help: 164
    Rate: 831
    Is it a cyclical clatter, repeating with a certain frequency, or a single clatter completely random?
  • #7 16382553
    kwok
    Level 40  
    Help: 494
    Rate: 1339
    It may be that the sachs disc but with a single shock absorber and it should be with a double shock absorber.
  • #8 16383131
    szy18
    Help: 8
    Rate: 127
    buddy DEVIL car do you have a retarder or without? I also had such knocks from the box at idle, it would seem that the box is about to fall apart. I drove like this for 4 years. after 500,000 km, replacement with Sachs in Wanicki, they chose the appropriate retarder discs and everything returned to normal. also my mother hen is probably right.
  • #9 16393188
    DEVIL 26
    When I come back, I will check the clutch package what the shield is and the knocks are cyclical but only on a cold engine and for about 15 minutes I will add that when the clutch is pressed, it is calm, but when the clatter comes back, the car will work 15 minutes and everything is quiet and ok
  • #10 16396582
    krisbrumm
    Help: 164
    Rate: 831
    Such knocking is most likely the result of backlash in the gearbox - quite common phenomenon ...
  • #11 16481808
    DEVIL 26
    Kris and you know what the cost of the repair is, whether you want to regenerate the box, or buy another one
    Added after 8 [minutes]:
    krisbrumm
    Help: 164
    Rate: 831
    There is no definite answer to this.
    It all depends. Generally, it is profitable to repair the gearbox, but only when one bearing breaks down or when one synchronizer is broken / worn. Replacing the gears is not economical.
    In turn, buying a used one is a great unknown - everyone says that the gearbox is functional from an almost new car so much that it had an accident. The world is full of naive people who believe in words. It's a lottery.
    It is bad either way. Gearbox repair is also time-consuming and in addition, not every Mirek can repair the gearbox correctly, although many declare that they will repair it. Special tools are needed, and not only a claw puller ...
    Low-to-top planetary gear failure is very costly. replacing all your bearings is also a financial killer. Anyway, ZF gearboxes are quite trouble-free and if you need to replace a pair of bearings, it means that the car must have about 2 million km, and then the question arises about the sense of melting money in a wreckage ...
  • #13 16482527
    kwok
    Level 40  
    Help: 494
    Rate: 1339
    krisbrumm wrote:
    if you need to replace a pair of bearings, it means that the car must be about 2 million km
    Not necessarily. All it takes is grandfather oil and the bearings are flying, I made a box on the bus, which was about 450kkm.
    krisbrumm
    Help: 164
    Rate: 831
    Who goes to the car that carries goods for a lot of money And costs almost a pail of rubbish oil ???
  • #15 16483246
    kwok
    Level 40  
    Help: 494
    Rate: 1339
    And there are those - economical, i.e. they minimize costs kosz, it is enough to stick the 75W90 gear gl5 on the ladybug rapeseed and the best oil available on the market is in the box. The second such social group are farmers - they also save in this way.
    krisbrumm
    Help: 164
    Rate: 831
    Stupidity to power. Buy a car for a lot of money to ruin it with ridiculous cheats. She has a horse and it is a waste of money for a bacik?
  • #17 16483681
    DEVIL 26
    and these medzebne slack as you called it, what regeneration cost I will add that the car has 800 thousand and I have it from new
    Added after 26 [minutes]:
    kris and you may know how which cable leads to the fridge because my voltage drops under load
  • #18 16509440
    krisbrumm
    Help: 164
    Rate: 831
    I don't know, but it won't pay off
✨ After replacing the clutch on a DAF XF 105 (2011), the user experiences a knocking noise from the gearbox that occurs for about 10-15 minutes after starting the engine, particularly when the clutch pedal is released. Responses suggest potential causes including the installation of a low-quality clutch, specifically mentioning that a Sachs clutch should ideally have a double shock absorber rather than a single one. Other contributors note that the noise may be related to backlash in the gearbox or issues with the retarder. The discussion also touches on the costs and considerations of gearbox repair versus replacement, emphasizing the importance of using quality components and proper maintenance to avoid further issues.
