Daf xf 105 2008. Transmission - Transmission warning illuminates red
marinero77 10518 1
  • #1 16797711
    marinero77
    While driving, the car started to jerk as if it had run onto a grater, it almost killed gears in manual mode, but pulled.
    1. Pressure bearing in working order, seated in the forks.
    2 the island works well visually
    I choose the third one for the second one
    The problem did not disappear error code after connecting Delphi:
    3117 Steering axle proportional valve 1 / Yaw
    I am asking for help what it could be
    • Daf xf 105 2008. Transmission - Transmission warning illuminates red DSC_1388.JPG (3.52 MB) You must be logged in to download this attachment.
  • #2 16799206
    klika60
    Help: 20
    Rate: 278
    Error 3117 clutch calibration or settings error. Clutch self-adjusting malfunction. Replace the clutch slave cylinder, but you probably have to replace the clutch.
