Audi A3 8L Fuel Gauge Issue: Incorrect Fuel Level Indication - Vag-Com Diagnostic & Adjustments
gustaw_s 8433 4
  • #1 16333434
    gustaw_s
    I have a problem with the correct indication of the fuel level, I know that the topic is rolled, but I have read a lot on various forums and I can not read anything about this problem. The point is that when I refuel the car fully, the pointer on the fuel gauge leans to the maximum to the right (i.e. for the indication 1/1) when I do 700-800 km, the pointer drops to a value a little below 1/2 Audi A3 8L Fuel Gauge Issue: Incorrect Fuel Level Indication - Vag-Com Diagnostic & Adjustments and points to the reserve for Fis.
    After connecting the Vag to the car, when it was fueled with FULL, the counter 17/30 was 121 (the adjustment range was from 120-130).
    I will add a scan from the car and there is some error in module 17:
    VAG-COM Version: Release 311.2-N
    1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
    Chassis Type: 8L - Audi A3 / S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01 ------------------------------------------------ -------
    Controller: 038 906 019 FH
    Component: 1.9L R4 EDC G000SG 1574
    Coding: 00002
    Shop #: WSC 06435
    WAUZZZ8L93A079406 AUZ5Z0C1057106
    No fault code found.
    Address 03 ------------------------------------------------ -------
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019458
    Shop #: WSC 06435
    Address 08 ------------------------------------------------ -------
    Controller: 8L0 820 043 J
    Component: A3 KLIMAUTOMAT 0105
    Coding: 00043
    Shop #: WSC 06435
    Address 15 ------------------------------------------------ -------
    Controller: 8L0 959 655 L
    Component: Airbag Front + Seite 7008
    Coding: 00104
    Shop #: WSC 06435
    Address 17 ------------------------------------------------ -------
    Controller: 8L0 920 900 K
    Component: KOMBI + WEGFAHRS. M73 D06
    Coding: 00040
    Shop #: WSC 00000
    1 Fault Found:
    01336 - Data Bus for Comfort System
    37-10 - Faulty - Intermittent
    Address 35 ------------------------------------------------ -------
    Controller: 8D0 862 257 B
    Component: ZV-Pumpe, Funk D16
    Coding: 14913
    Shop #: WSC 06435
    2 Faults Found:
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    End ------------------------------------------------- ------
  • #2 16333700
    autoas
    Help: 571
    Rate: 3926
    Do the indicator test a few times, maybe the motor itself is damaged ...
  • #3 16333897
    gustaw_s
    When I do the test of tips, all but the one from the fuel are nicely vertical, and the one from the fuel shows 3/4. Alternatively, can the motor itself be replaced in the meter ??
  • #4 16333936
    autoas
    Help: 571
    Rate: 3926
    Of course it is possible ...
  • #5 16344210
    UCY 7400
    Help: 37
    Rate: 75
    Poorly seated needle or motor damaged. In case of what I can replace ;)
