Experiencing Black Screen on Cyfrowy Polsat Channels: TVP 1 and Eleven Sports with HD6000 Decoder
dan1660 14202 19
How can I fix black screen and freezing on only TVP1 and Eleven Sports with a Cyfrowy Polsat HD6000 decoder and a 60 cm satellite dish?
The most likely fix is to realign the satellite setup, especially the LNB tilt/skew and possibly the whole dish, not to add an amplifier. A 60 cm dish is considered too small here, and an 85 cm dish was recommended instead [#16334296][#16334461] Check the signal parameters on the problematic channels while gently adjusting the LNB angle; if that is not enough, have the dish tuned more precisely [#16334461] The cable should also be replaced if it is several years old or has damaged insulation [#16334526] The nearby Wi‑Fi/LTE router is less likely to be the cause if disconnecting it makes no difference [#16334383][#16334435]
  • #1 16334276
    dan1660
    I have a problem with 3 channels in a digital TV, exactly tvp 1 and eleven channels. All other channels work normally, but as I turn on the above-mentioned dots they charge to the end and almost always the black screen is and sometimes the image is jamming. Signal strength 100% and signal quality over 60%. I was thinking about buying an amplifier but I do not know if it would help. I have 60 cm hat and HD6000 decoder. Please help.
  • #2 16334296
  • #3 16334324
    _kli_
    Help: 760
    Rate: 1038
    Are there no WiFi routers near the decoder or aerial cable? What are the parameters of the signal on these channels (press and hold the red button on the remote for a while)?
  • #4 16334326
    dan1660
    and an LTE router that is 20-30 cm away from the decoder can also affect?
  • #5 16334338
  • #6 16334346
    dan1660
    the signal strength jumps from the red bar to 100% and the quality from red to yellow.
    I have a wifi router near me
  • #7 16334350
  • #8 16334371
    dan1660
    I do not have one cable installation. I have an unrelated Internet connection received by a wifi router and I receive television via the antenna
  • #9 16334383
    _kli_
    Help: 760
    Rate: 1038
    Unplug the router for a moment and see the effect. If it helps, you must move the router away from the installation so that it does not interfere.
  • #10 16334384
  • #11 16334404
    _kli_
    Help: 760
    Rate: 1038
    mihal2002 wrote:
    Do you know how it's connected? Turns off the router and Loop does not work
    I therefore think that there is no ODU-ID.
  • #12 16334405
    dan1660
    The Internet I have on the card received by the router and the router is not connected to the bowl to which the television is connected. The TVs are connected by an antenna cable to the convector in the bowl. I am asking for information because I have no idea about it?
  • #13 16334423
  • #14 16334435
    dan1660
    router disconnected from the internet and further such an effect.
    and changing the angle lnb can be done by yourself or do you have to call a fitter to do it?
  • #15 16334461
    _kli_
    Help: 760
    Rate: 1038
    dan1660 wrote:
    and you can change the angle of lnb yourself
    This is not very difficult, but you have to do it by observing signal parameters on problematic channels. If it does not help, then the whole plate probably needs delicate tuning, so it's better
    And by the way the exchange of the canopy for the larger one is highly recommended.
  • #16 16334467
    dan1660
    and replacing the lNB Convector with a new one because the bowl was assembled from 8 years ago was not also indicated?
  • #17 16334484
  • #18 16334505
    dan1660
    OK I understand. The last question is whether to replace it also at the same time because the cable is already several years old and there are a few rubbed rubber on the cable?
    3.1.13. Publishing entries that violate the spelling rules of the Polish language, careless and incomprehensible.
  • #19 16334526
  • #20 16339623
    misyogi65
    mihal2002 wrote:
    Well, obviously for exchange. Only buy brand and not price.
    Of course, for exchange.
The discussion revolves around a user experiencing a black screen issue on specific channels (TVP 1 and Eleven Sports) while using a HD6000 decoder. Other channels function normally, and the user reports a signal strength of 100% and quality over 60%. Suggestions include checking for interference from nearby WiFi and LTE routers, adjusting the LNB angle, and considering the replacement of the LNB and coaxial cable due to age and wear. The user is advised to disconnect the router to test for interference and to potentially upgrade to a larger satellite dish for improved signal reception.
