daf xf 105 460 2006 - engine warning turbo pressure after turbine replacement
janas74 5973 4
  • #1 16335139
    janas74
    engine warning light error turbo pressure lights up. The replaced turbine gives 1.4 at a standstill.
  • #2 16335977
    kisiol
    Help: 36
    Rate: 468
    Sensor damage, not tight intercooler intake rubber connecting system. Check the vent valve.
  • #3 16342214
    hubert04
    Help: 60
    Rate: 407
    at standstill there is no such option for the turbo to reach 1.4 bar bad diagnosis in the parameters what do you read by autocom? kisiol as to "Check the vent valve" in this engine there is no such valve occurs only in 510
    buddy janas74 enter the error number from DMCI then there will be something you can say do not give a description
  • #4 16342280
    kisiol
    Help: 36
    Rate: 468
    If you say that there is no valve.
    • daf xf 105 460 2006 - engine warning turbo pressure after turbine replacement 20170313_093840.jpg (1.71 MB) You must be logged in to download this attachment.
  • #5 16342800
    hubert04
    Help: 60
    Rate: 407
    this is a normal pressure relief valve called westegate is a valve with electric control but less so
