DAF XF 105 460: LIMITED ENGINE POWER Warning, Exhaust System Fault - Causes & Advice
jerzyk464 9060 4
  • #1 16665744
    jerzyk464
    Hello, I have a problem with the Dafem xf 105, there are two warnings on the display, one with a fault in the exhaust system and the other with a limited engine power. What may be the reason, please give me some sensible advice
  • #2 16665782
    nici
    Help: 266
    Rate: 979
    Adblue possibly, possibly EGR.
  • #3 16665807
    MobilTruck
    Help: 139
    Rate: 965
    nici wrote:
    possibly EGR
    Mx 340 does not have EGR. As a colleague wrote, Adblue system to be checked.
    Either way, there will be no diagnostics.
  • #4 16665816
    nici
    Help: 266
    Rate: 979
    pitool wrote:
    The Mx 340 has no EGR
    Possible, I wrote about common causes of safe mode:]
  • #5 16702393
    Kazor26
    Rate: 37
    How long does the car have to travel? Adblue to be checked. You need to connect the computer. After 500 thousand Very often the Nox sensor crashes, it costs 1300 net expensive equipment. Usually, the Nox behind the catalyst limits the power, but I say first, I advise you to go to the computer
