opel astra h 1.6 twinport - replacement of the engine control for used
Siekier81 13773 12
Can I adapt a used engine control unit to my Opel Astra H 1.6 Twinport without the PIN code, or do I need to clone data from the old ECU?
You cannot assign a used ECU to the car with OP-COM without the PIN code [#16478812] The practical option suggested is to buy a controller with a known PIN or one that is already logged out [#16479087] Another reply says the PIN can be read after connection with the right tool, and a SMOK programmer was given as an example [#16479255][#16482140] Repairing the old ECU was also discussed, but one repair shop said that because the fault is intermittent they would not take it in [#16478950]
  • Used ECU may need PIN code and memory transfer
    #1 16478724
    Siekier81
    Help: 9
    Rate: 175
    Hello. I have a question whether without the driver's pin code which I intend to buy I am able to assign it to the car op-comem. Generally, the car has a broken driver because after warming there is no control for one injector and the car goes on 3 cylinders. I wonder about overdraft memory from the old driver to the new (used) which would probably settle the matter of ecu exchange as soon as possible. Only a question to the experts, what memory sits there. Driver delphi delco fahf D04004. 12230740.Auto to astra H 1.6 twinport
  • #2 16478812
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Siekier81 wrote:
    whether without the driver's pin code which I intend to buy, I am able to assign it to the op-com vehicle
    You will not do anything without a PIN
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16478841
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Give the driver for repair as soon as 1 fit does not work.
  • #4 16478889
    Siekier81
    Help: 9
    Rate: 175
    I have undressed the driver to review the solder. There is no problem with overflowing. The driver is not flooded with thin threads connecting the pins with the plate. Theoretically, it looks good. Just where is the pin sitting there?
  • #5 16478907
    adam7009
    Help: 656
    Rate: 1635
    pin not a problem, but a driver needed, you would have to send.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #6 16478950
    Siekier81
    Help: 9
    Rate: 175
    I do not have a second driver yet. I just do not know whether to give it to repair or buy a second one and combine it with immo.
    Added after 10 [minutes]:
    I just called the company that repairs the drivers and I got the info that as the fault happens sporadically as in my case it will be a problem with repair. They do not want to take it. So, I think it's only the option with the stimulant.
  • #7 16479087
    adam7009
    Help: 656
    Rate: 1635
    buy a driver with a known pin or logged out.
  • #8 16479155
    Siekier81
    Help: 9
    Rate: 175
    ok. Only that I can not find the driver number logged out or with the pin. All that sell drugs is without any codes. It would be like somebody gave up whatever souvenir is sitting here that I would be tempted to fly.
  • #9 16479248
    Help: 1405
    Rate: 6430
    Give a picture of the middle.
  • #10 16479255
    adam7009
    Help: 656
    Rate: 1635
    why open it, everything is done after the connection.
  • #11 16481206
    Siekier81
    Help: 9
    Rate: 175
    I will put the picture tomorrow because I can not do it today. And how can it be read after the connector. What device?
  • #13 16488066
    Siekier81
    Help: 9
    Rate: 175
    Hello. As for now, it is not on my budget such equipment from this company. What I am so far at the stage of looking for a driver logged out or with a pin.
The discussion revolves around the replacement of the engine control unit (ECU) for an Opel Astra H 1.6 Twinport. The user is facing issues with one injector not functioning, causing the engine to run on three cylinders. They inquire about the possibility of programming a used ECU without the driver's PIN code and whether memory from the old ECU can be transferred to the new one. Responses indicate that the PIN is necessary for programming, and suggest either repairing the existing ECU or purchasing a second-hand unit with a known PIN. The user expresses difficulty in finding a suitable replacement ECU with the required codes and is exploring options for diagnostic tools to read the ECU data.
