Connecting two computers with Windows 10 and Windows XP to the network
bpm 12321 9
How do I connect a Windows 10 PC and a Windows XP PC on the same router so they can see each other on the network?
Use the same router, put both computers in the same workgroup, and do not rely on HomeGroup because Windows XP does not support it [#16341659] [#16341991] [#16341984] On Windows 7/10 this is configured from the computer’s Properties; the reply specifically points to right-clicking My Computer and opening Properties to change the workgroup [#16341991] If the goal is just to make them “see each other,” clarify whether you mean network browsing, shared resources, or pinging, because that affects the exact setup [#16343854]
  • #1 16341464
    bpm
    Rate: 22
    Good evening,
    the problem may be very simple for others, not for me, because I did not do it in my life and that's why I write in this section.
    Well, there is a program (irrelevant at this point) that is supposed to work in a network between two computers. It is necessary that one of the computers (from Windows 10) be a "server" and the other (with Windows XP) "workstation". The point is that they "see each other". The one with Windows 10 connects to the router via Wifi, the other the normal Ethernet connection.
    The question is what to do, how to do, where to start? I am looking for the net and the concept I do not have how it should be, home network, local network, home group, or somehow different? As I wrote, for some it can be simple, not for me, because I did not do it, but please take it seriously. Thank you.
  • #2 16341659
    sosarek
    Help: 9320
    Rate: 15532
    Computers connect to one router?
    Both of them set the same homegroup?
    Z
    Pka, Poznań, 60-850
  • #3 16341774
    bpm
    Rate: 22
    Yes with one router.
    Nothing was done, no home groups, nothing. I wrote above, I did not do something like that in my life, I have no idea what to do.
  • #4 16341782
    sosarek
    Help: 9320
    Rate: 15532
    bpm wrote:
    I did not do such a thing in my life, I have no idea what to do.
    Google is not working?
    Z
    Pka, Poznań, 60-850
  • #5 16341799
    bpm
    Rate: 22
    I love such answers. Go to a tree and go to google.
    Works and so what? If I knew what to look for, how to look and how to do it, I would not write here and ask for help. It's probably logical, right?
    For example, for the first time in your life you see a car and tell you to drive it, will you go? I do not think so. Someone can tell you, there were no books?
    Once again, if I knew what to do and what to look for, I would not ask for help. Where should I start? What to look for?
  • #6 16341840
    sosarek
    Help: 9320
    Rate: 15532
    No - you are waiting for a ready, the answer has already been made.
    It took me two seconds
    Z
    Pka, Poznań, 60-850
  • #7 16341984
    bpm
    Rate: 22
    No, I'm not waiting for a cook. I am counting on help because I do not know myself completely.
    You write about the home group, and I found a topic like this:
    https://www.elektroda.pl/rtvforum/topic2672017.html
    Second answer: "Windows XP does not support the home group" And what do you say?
  • #8 16341991
    sosarek
    Help: 9320
    Rate: 15532
    I like it for the summer, if you read it you would know that computers should work in the same workgroup, on Windows 7 it is simply easier to configure.
    In short - PPM on My Computer - Properties ...
    Z
    Pka, Poznań, 60-850
  • #9 16343782
    KOCUREK1970
    Help: 3860
    Rate: 5488
    bpm wrote:
    the second (with Windows XP) "workstation".
    Is SP3 installed there (on this XP)?
  • #10 16343854
    zibq
    Help: 83
    Rate: 181
    What does the author mean by saying that computers are to be seen? In a network environment? Is it possible to view shared resources? Should they ping? Or maybe it is not about the TCP protocol at all? What is the operation of this "irrelevant" program?
    The answer may be simple, but you must specify the question or provide more details.
The discussion revolves around connecting two computers, one running Windows 10 and the other Windows XP, to a network where the Windows 10 machine acts as a server and the Windows XP machine as a workstation. The user seeks guidance on establishing a home or local network, as they are unfamiliar with the process. Responses suggest ensuring both computers are on the same workgroup, as Windows XP does not support homegroups. Additionally, the importance of having Service Pack 3 (SP3) installed on the Windows XP machine is highlighted. Clarifications are requested regarding the visibility of shared resources and network protocols involved.
