Windows 10 (1803 Update) Network Visibility Issue: Computers Not Seeing Each Other on LAN
kawaczekolada 849 3
  • Credentials rejected when connecting to visible LAN PCs
    #1 20617126
    kawaczekolada
    I went through all the advice on this thread, watched all the videos, applied all the solutions. I've probably done it 100 times already :) However, the computers still don't connect. They are visible on the network, but when you try to connect and enter your credentials, they are incorrect. Any of you have any advice?
    Moderated By dt1:
    Separated from the archival thread: https://www.elektroda.pl/rtvforum/topic3470684.html - in other people's threads, we add advice for the author of the thread, not our own problems.
    The spelling has been corrected, please take care of it in future posts.
  • #2 20617140
    artaa
    Help: 1819
    Rate: 1700
    Create the same user on each computer, e.g. user
    with the same password e.g. user1
    test...
  • #3 20617153
    kawaczekolada
    Did not help. Strange, because I have access from one computer and not from the other. The settings are the same.
    >>20617140
    I changed advanced settings. Now it doesn't require a password, so you don't get prompted for credentials. It only works one way.
  • #4 20617164
    artaa
    Help: 1819
    Rate: 1700
    If the settings from the video also do not help, then only ineffective prayers to MS remain.
    I had such a case a long time ago, it was faster to reinstall Windows...
