T4 2.5 ACV: Timing Adjustment, VW Pump Settings, Car Performance on Warm vs Cold Engine
Ryba29 19320 5
  • #1 16346510
    Ryba29
    Hello, I'm new here I have a problem with T4 2.5 car I bought a long time ago someone replaced the timing car burns well on a warm on a cold worse I tried to set the pump to vag but the values do not change after adjustment I will add that the pump is not set on the sign only the sign is almost the tooth below as set on the sign the car will not fire. Could be a pump or regulator, please help and thank you in advance
  • #2 16346552
    oktawian89
    Help: 52
    Rate: 444
    The injection pump wheel drive is from the rear wheel to the head. The wheel is floating. Set the shaft to 0, there is a lock for this wheel. Loosen the wheel itself until it rotates freely. Then you just pull the fin on the pump, set it on the clock and turn the wheel on the head.
    PS
    Remember the shaft rotates in relation to the 2: 1 injection pump wheel !!
  • #3 16347852
    manta
    Help: 463
    Rate: 1533
    Write in Polish. That the sign comes out below is the norm. You pre-set the dial indicator, then control from the level of the tester. You may have a faulty injection account change valve, strictly O-rings, or muck.
  • #4 16347983
    diesel022782
    Help: 13
    Rate: 116
    hello this sign, when it is in the plane, screw up to the start of pressing, injection, loosen the drive wheel, these pumps on the camshaft and give one kill forward, the wheel is on the very slope
  • #5 16348208
    Ryba29
    Ok, the problem was already done was the water temperature sensor pump set sensor new thanks
  • #6 16348383
    diesel022782
    Help: 13
    Rate: 116
    and it's good that you usually managed it, it doesn't heat through the sensor, but it is also cold too, greetings
