Dash Cam Interference with Car Radio Waves: Seeking Reasons
dzedaj2000 8358 8
  • #1 16347611
    dzedaj2000
    Rate: 37
    Hello, when I have the car radio turned on and I turn on the video recorder, the radio suddenly loses its waves. What could be the reason?
  • #2 16347627
    Ture11
    Help: 574
    Rate: 1132
    Most likely the device's inverter is causing interference.
  • #3 16347647
    dzedaj2000
    Rate: 37
    Any easy way to stop this interference?
  • #4 16347652
    pawelr98
    Help: 413
    Rate: 1156
    Either a better converter or linear power supply.
    Linear will not be bothersome somehow because this video recorder probably does not download too much.
    For a test, you can also quickly wrap the device in aluminum foil and see if it gives way.
  • #5 16347666
    dzedaj2000
    Rate: 37
    Mirror type video recorder It is strange that there is no written model.
  • #6 16353489
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    dzedaj2000 wrote:
    Mirror-type video recorder.
    Power supply inside or on the lighter?
  • #7 16353766
    dzedaj2000
    Rate: 37
    On the lighter.
  • #8 16353860
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    Give a 12v stabilizer at the input.
    I had a similar problem with GPS coverage in navi.
    When I turned on the recorder, navi (added to the glass) did not catch the satellites.
    The stabilizer did it positively.
  • #9 16361960
    dzedaj2000
    Rate: 37
    I sold
The discussion revolves around the interference experienced when a dash cam is activated while the car radio is on, leading to a loss of radio waves. The primary cause identified is the inverter of the dash cam, which can disrupt radio signals. Suggested solutions include using a better converter or a linear power supply, which is less likely to cause interference. A temporary test involves wrapping the device in aluminum foil. Additionally, the use of a 12V stabilizer at the input is recommended, as it has resolved similar issues with GPS devices in the past.
