[Solved] Saab 9-3 '06 ICM3 Car Radio Display: High-Frequency Squeak Linked to Backlight Brightness
cinek22224 13089 5
  • #1 16348958
    cinek22224
    Good morning everyone,
    I am asking you for help in diagnosing the problem on the Saab 9-3 '06 ICM3 car radio / display. When it is turned on, a high-frequency uniform squeak appears from the display area. Its volume increases as the brightness of the backlight of the dashboard with the display increases. Over time, when the radio is turned on, i.e. about 10 min, the squeak volume decreases a little but is still audible.
    Today I noticed one more regularity, namely after entering the tunnel, the squeak volume decreases significantly, so it may be related to the FM signal, however, anticipating the questions, the squeak is as much on FM as on CD or AUX.
    Do you have any idea what the problem might be?
    Thanks for the help!
    Regards
  • #2 16349090
    mipix
    Help: 495
    Rate: 1486
    The source of the squeak may be a converter supplying the LCD backlight
  • #3 16349109
    cinek22224
    Thanks for the answer. What could be the reason? Maybe the inverter choke is poorly wound?
  • #4 16557902
    LWD11
    Help: 223
    Rate: 486
    Hello, did you handle this screech from the inverter?
    I just have such art inside there is not much to attach to.
    Certainly the squeal comes from the display inverter. For cold solder, everything is ok.
    Is it good to exchange?
  • Cracked display board spot fixed with adhesive
    #5 16558134
    cinek22224
    Hey,
    it can be said that the problem has been solved. The squeak came from a small spot (visible in the photo - 330) on the display board
    With a stronger touch this "housing" slightly cracked so I advise you to be careful. I flooded the "drop" through the crack and waited for it to dry. The squeal stopped.
    I know it would be best to replace the item but I have not found it anywhere :)
    Regards
  • #6 17948462
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Resolved topic :arrow: I shut.
