Peugeot 407 SW 2.0 HDI 136HP - Auto jerks or goes out, error P1166 and P1164
hellgt 33507 14
Why does a Peugeot 407 2.0 HDI jerk and stall with P1164/P1166, and what should be checked first?
The most likely practical fix reported in the thread was to replace the crankshaft position sensor, which completely solved the intermittent stalling and restart problem even though the car originally showed fuel-pressure-related errors [#20768454] Before that, it is also worth checking the fuel side: replace the fuel filter first [#19785545] If the fault remains, inspect the common-rail system for a faulty rail pressure sensor/transducer, pressure regulator, maximum pressure limiter, and injector leakage/corrections, because one reply noted that a leaking injector can cause rail-pressure problems under load [#19786551] Another suggestion was that the rail pressure may be too high or the pressure sensor itself may be defective [#16355558] A further possibility mentioned was a weak fuel pump or dirty/defective injectors [#16355562]
  • #1 16355077
    hellgt
    Rate: 9
    Maybe someone will help me. For some time I have a problem with the car going out, usually jerks for a while with a stronger addition of gas and sometimes the extinguishing seems without reason ... This problem had already before the mechanic replaced the fuel filter and the crankshaft position sensor and was calm for 3-4 months but for some time the problem has come back again ... I don't know if something is happening again or something new but with similar symptoms. Apparently, the injections show abnormal ...
    He sends me the error codes P1166 and P1164
    P1166 -> High pressure fuel regulation, Measured rail pressure higher than the maximum pressure
    P1166 -> Fuel pressure control. Pressure too high.
    P1164 -> Fuel pressure sensor test, SID 801 - Fuel pressure signal.
    P1164 -> Transient error, fuel pressure signal, pressure change consistency
  • #2 16355558
    rafal35
    Help: 23
    Rate: 47
    After errors, it seems that the pressure on the strip is too high or the pressure sensor is broken and maybe it is worth starting with.
  • #3 16355562
    norbertos988
    It is also possible that the fuel pump feels bad, or it is also worth cleaning the injection or replacing it
  • #4 16356153
    rafal35
    Help: 23
    Rate: 47
    norbertos988 wrote:
    the fuel pump is not feeling well
    I think the pump can handle it because the pressure is too high.
  • #5 16359799
    hellgt
    Rate: 9
    Today my car stopped on a cold engine after driving 20 m: / Just went out and did not want to start ... only after about 5 minutes and using the spray starter I was able to start again and drive almost 30km without a problem ...
    When I came home, I did not turn off the car and another error appeared to me P0337-> Crankshaft position sensor A low input signal, P0336 Crankshaft position sensor A - signal out of range
    It seems to me that when the timing was replaced it was possible that special attention was not paid to this sensor ... or even accidentally damaged ...
    Where exactly is this sensor located? I am asking for an explanation like this for a layman because I am not a specialist myself and I do not even know the elements in the car, it is best if you can take the photo with a clearly marked element. Thanks in advance
  • Fuel rail pressure faults suggest regulator or pump issue
    #6 19785233
    tunio99
    Rate: 11
    Good morning
    I'll step on it. My C5 2.0 hdi RHF 140 KM went out while driving and it won't start. The "magic box" showed the errors: P1351 - glow plug circuit, P1164 and P1166 both point to the fuel high pressure circuit, the parameter preview showed the start fuel pressure 150 to 160 MPa, which is 1600 bar. This is the maximum performance of the toilet pump, does it mean a damaged or clogged or jammed fuel pressure regulator? Or maybe something else?
    There was still an error P0336, but after it was deleted, it did not appear again.
  • #7 19785500
    lukaszmech
    Level 19  
    Help: 26
    Rate: 48
    if the pressure sensor on the rail is damaged, you will not start the car. Check that there is no oil on the plug from the rail pressure sensor, I recently processed it in 1.6 hdi and 2.0 hdi, I started the plug from the rail and the car went out amen. Until the pressure comes off the rail, you will not start the car
  • #8 19785508
    tunio99
    Rate: 11
    The car cannot be started at all, even after a few days of inactivity.
    The magic box, when the ignition is turned on, gives a pressure of zero. At
    turning the starter, the pressure reading increases quickly to about 150 MPa.
    As long as it spins, it maintains that pressure; after releasing the key and stopping it,
    the pressure reading slowly drops to zero.
  • #9 19785525
    lukaszmech
    Level 19  
    Help: 26
    Rate: 48
    question the fuel filter has been replaced?
  • #10 19785530
    tunio99
    Rate: 11
    Soon the time will come, because for 2,000 km oil change,
    and I change the fuel filter every two oil changes.
  • #11 19785545
    lukaszmech
    Level 19  
    Help: 26
    Rate: 48
    replace the fuel filter at the beginning, this is my advice
  • Fuel pressure spikes to 160 MPa during cranking
    #12 19786418
    tunio99
    Rate: 11
    In addition, because in the heat of the battle it fled:
    it's not the first time it's gone out.
    The first time it went out while driving was about two months ago.
    Just - yes - it has gone out, without symptoms, freaking, jittery,
    it just drove on and went out. By the force of my momentum, I rolled to my place
    on the street and parked. The starter cranked but the engine would not fire.
    There is a message that the electric brake is malfunctioning
    parking, although this one worked flawlessly. He reappeared fairly quickly
    ECONOMY MODE ACTIVE. But maybe it's because the battery is 4 years old.
    The next day it fired, admittedly with the "helicopter" icon, but
    I got home. I connected my "magic box" for 4 tenants
    and I read errors P0336, P1351, P1166 on a free application on a smurfon
    and P1164, which after deleting and re-firing several times
    have not returned. Then, after a good month, the car went out while driving
    again, but after the car stopped at the edge of the street, it fired at the first
    together. The check icon flashed on and went out after being triggered several times
    engine. Same errors again and again did not return after being deleted.
    A few days ago, the car went out again while driving and this time it is no longer working
    to run. Errors P1164 and P1166 after resetting and attempting to start
    they are coming back. The parameter reading shows that the fuel pressure is zero on
    idle, when you try to start it quickly increases to 150 or even 160 Mpa,
    which is the maximum efficiency of the toilet pump. She keeps it that way while filming
    when stopped, it slowly drops to zero.
  • Injector leak causing rail pressure drop
    #13 19786551
    Telex
    Help: 106
    Rate: 100
    Please check what the CR injection looks like. And take a look at what you got there. In addition to the high pressure pump, you also have: a maximum pressure limiter, a pressure regulator controlled from the ECU, a pressure transducer to measure this pressure and the injections themselves.
    Maybe the pressure regulator is the problem, as it regulates the correct pressure. The problem may be the injections themselves, so check the injection corrections on the working engine. or the pressure overflow itself.
    I used to be mechanics in P407 2.0HDI 2007. they wanted to replace the filter, pump, regulator, rail, all injections one by one. And it turned out that one injection, when it got the temperature, poured down and the pressure on the rail decreased, but it was noticeable after the injection corrections - tracked while driving until the error occurred.
    We can't solve everything for you. We can only guide you. The order of replacement should also be decided by the price of new parts, so if the limiter or regulator is cheaper than the pump and injectors, then they should go to the first fire.
  • Crankshaft sensor replacement fixed intermittent no-start
    #14 20768454
    tunio99
    Rate: 11
    Forgive me for being out of touch for so long. The car, after a few days "by itself," started up. Just like that, by itself.
    Then the situation repeated again in March and again in July. I came to my senses
    and began to ask someone wiser than myself. And someone (I will not advertise him because he runs a workshop
    and specializes in Citrines) advised me to "in the dark" replace the main shaft sensor.
    If this does not help, then bring him the car.
    The sensor did not cost much, so I replaced it.
    O!!!!! Play the trumpets of triumph!!!!! The car healed, and from now on, it starts at the sight of the key. Zero problems.
    I'm such a mechanic/electronics/diagnostician, but it counts that I "fixed it".
  • Crankshaft sensor replacement questioned for P1164/P1166
    #15 21722893
    zaurpaschaev91
    I have the same symptoms and the same error codes (P1164, P1166).
    One specialist told me that if there are no specific error codes related to the crankshaft sensor, I shouldn’t replace it.
    What do you think?
    My car runs, but the idle speed is unstable, the engine shakes a bit, and when it stalls, those same errors (P1164, P1166) used to appear — but not anymore.
    Now it sometimes starts only after 2–3 attempts.
    What would you recommend I do?
Discussion about a Peugeot 407 SW 2.0 HDi with intermittent stalling, jerking under acceleration, unstable idle, and occasional no-start conditions. The main fault codes are P1166 and P1164, indicating excessive common-rail fuel pressure and fuel pressure signal inconsistency. Suggested causes include a faulty rail pressure sensor, fuel pressure regulator, high-pressure pump, injectors with abnormal corrections/leakage, or a clogged fuel filter. Later symptoms also included P0336/P0337 crankshaft position sensor faults, and replacing the crankshaft sensor eventually resolved the repeated stalling/no-start issue.
