Reversing Camera Cable Extension Issue: 1m, 2.5 Jack Plug, Connection Diagram, Driving Recorder
marcinos1989 10311 1
  • #1 17109021
    marcinos1989
    Rate: 36
    I have a reversing camera for the driving recorder. Everything works fine, I only have a problem because the cable from the camera to the recorder is
    too short, so I thought I would buy an extension cord, but after plugging it in, it doesn't detect the camera. Fig. 1 camera ended with a jack plug 2.5 Fig. 2 jack extension cable 2.5
    does anyone know the connection diagram? I would like to cut this extension cord and change the order of the cables? Or anyone has any other idea?
  • #2 17110037
    KMal
    Help: 340
    Rate: 1434
    Such things usually have their unusual cables that do not comply with any standard, so it is difficult for someone to remember the "scheme" of the connection by heart.
    Of course you can easily extend it, but
    without changing the order, only exactly the color to the color, i.e. in harmony - but not the extension only the original. You will miss the investigation as to what (diagram).
    The extension you bought does not provide power, so it is not suitable.
    Before converting, check that this camera is still working after testing on this extension.
