DAF XF 105 460: AdBlue System Warning, Power Limitation, and Exhaust System Errors
rafaltom0 24489 7
  • #1 16359131
    rafaltom0
    Rate: 12
    Hello, the car displays the error: Exhaust system warning (also the exhaust indicator light is on), then limits the engine power.
    In the autocom, it easily reads the exhaust gas temperature before and after the catalyst, while NOX concentration sensors (before and after) display the message: Not ready or inactive.
    One more parameter puzzles me, whose screen is included in the attachment.
    DAF XF 105 460: AdBlue System Warning, Power Limitation, and Exhaust System ErrorsBez tyt...png (182.76 kB)You must be logged in to download this attachment.
    Gentlemen, generally where to start, or how to diagnose it so as not to spend a fortune on it ??
    I will be grateful for any hint.
  • #2 16360369
    kisiol
    Help: 36
    Rate: 469
    Start by reading the error codes.
  • #3 16362503
    krisbrumm
    DAF Trucks specialist
    Help: 164
    Rate: 831
    Sorry for the honesty, but you take the diagnosis without knowing what to expect.
    The NoX sensor does not generate a nox signal until the temperature of the NoX sensors exceeds 350 degrees Celsius. So, realistically, an engine gassed at a standstill until death, will never create such a temperature of exhaust gases that NoX sensors generate a signal with NoX concentration in real time.
    As the previous speaker said, enter active error codes.
  • #4 16362894
    rafaltom0
    Rate: 12
    Mistakes:
    DAF XF 105 460: AdBlue System Warning, Power Limitation, and Exhaust System ErrorsBez tyt...jpg (79.31 kB)You must be logged in to download this attachment.
  • #5 16362981
    kisiol
    Help: 36
    Rate: 469
    It turns out that noxy to exchange.
    Check AdBlue fuses, pump connections, and NOx sensor wiring
    #6 16363029
    kakibara
    Help: 202
    Rate: 1284
    You can help a little before spending a fortune, clear mistakes, make a 15 km route by car, and read the errors, in the meantime check
    fuses,
    disconnect plug from pump pump spray to improve contact reconnect plug, check the battery from the frame side if there is no green coating in the plugs, if there are visible pins in the Nox sensor and inside the plug.
    Each diagnostic program - I have never used it before - has a tab with system process activations, e.g. air supply, activation of the adblue dispenser, etc.
    In general, you can have two nox sensors to replace - but first the beam to check. pump - sensors.
  • #7 16363386
    rafaltom0
    Rate: 12
    Just after clearing the errors and driving about 15km errors appear again. I eat today and check the plugs. So if nothing gets better, NOXs need to be replaced :(
  • #8 16383966
    rafaltom0
    Rate: 12
    Replacing the sensors solved the problem.
The discussion revolves around a DAF XF 105 460 experiencing an exhaust system warning, indicated by a warning light and subsequent engine power limitation. The user reports that while exhaust gas temperatures can be read, the NOx concentration sensors show as inactive. Responses suggest starting with error code diagnostics, checking the NOx sensors, and ensuring proper connections and fuses. A follow-up indicates that after clearing errors and driving, the issues reoccur, leading to the conclusion that replacing the NOx sensors resolved the problem.
