Orion 32LBT731 TV, Vestel 17IPS19-5 power supply - no standby
LisuuuPL 10497 17
Why does the Orion 32LBT731 with a Vestel 17IPS19-5 power supply have no standby LED, and what should I check first?
Check the primary mains input stage first: the main filter capacitor should have about 310 V DC, so the 210–220 V you measured at the “left pin” is not the correct reference point; inspect the AC input path, rectifier diodes, and NTC [#16361726]
  • #1 16361605
    LisuuuPL
    ORION 32LBT731 TV set
    Vestel 17IPS19-5 V1 061112 power supply
    17MB82S module
    VES315WNVS matrix
    Standby LED is missing
    He was completely dead at first. The fuse 3.15A 250V (F100) was blown
    After replacing the fuse with a new one, the standby diode was on for a few seconds.
    When you try to turn on the TV, the diode has gone out and does not light up so far,
    On the board, all diodes, capacitors etc are good.
    The TR300 converter squeals, but it has 210-220 V voltage.
    The TR200 converter does not squeal and also has 210-220 V .
    According to the diagram I am looking at, the output voltages are good:
    5 pin 23.8V
    7 pin 12.2V
    8 pin 12.2V
    11 pin 5V
    12 pin 12.2V
    Each pin has 5V on the Standby board - the LED is off.
    I checked the resistors - they are good.
    The LED power socket (PL500) has a voltage of 23.8V.
    When I touch the IC301 with the meter, the inverter squeaks a little differently.
    IC301 - 11V
    IC200 - 20V
    IC302 - 1.5V
    Where to find the fault? Help!
    • Power Supply 17IPS19-5 Philips VES2.2E LA.pdf (1.17 MB) You must be logged in to download this attachment.
  • #2 16361667
    GanCegall
    Help: 339
    Rate: 1631
    What is a standby board? Any markings?
    LisuuuPL wrote:
    IC301 chip
    It's called somehow?
    LisuuuPL wrote:
    IC301 - 11V
    IC200 - 20V
    IC302 - 1.5V
    What is this?
    It is impossible to write what is missing, its designation, location and what is mounted?
  • #3 16361694
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6435
    LisuuuPL wrote:
    The TR300 converter squeals, but it has 210-220V voltage.
    The TR200 converter does not squeal and also has 210-220V.
    Where is 220v?
  • #4 16361706
    LisuuuPL
    On the left knife - at the entrance and exit
  • #5 16361726
    Help: 1405
    Rate: 6435
    There should be 310V on the input capacitor.
    Check all 220V AC power, diodes and NTC.
  • #6 16361733
    GanCegall
    Help: 339
    Rate: 1631
    LisuuuPL wrote:
    On the left knife
    And from which side? :-) TV is not a bicycle, left pedal, right pedal ...
  • #7 16361787
    LisuuuPL
    Just like I added a photo. Only on the left foot is 210-220v
  • #8 16361806
    GanCegall
    Help: 339
    Rate: 1631
    Buddy, if you don't start calling things by their names, unfortunately we can't help you, it's obvious that, for example, in pottery there is a term for left or right rotation, but in electronics you have to be more specific.
    I have asked a few questions and expect specific answers.
  • #9 16361838
    mirex
    Help: 1950
    Rate: 1990
    Put it on. ;)
    Strumien swiadomosci swia wrote:
    Where is 220v?
    And after ours it must be Where is 220V?
    Why if the repairman claims all output voltages are correct?
    I know he doesn't know what he is saying, but I believe it. :)
    Mate repairman, ... stand back, leave that TV alone, learn simple things.
    The TV is a pity for your DIY. ;)
    At least I hope your will, so your will, you may even use a hammer. ;) But it's a pity anyway. :)
  • #10 16361941
    GanCegall
    Help: 339
    Rate: 1631
    Do I know, quite a good description of the components, except for the diode that is lit although it is not there :-)
    But it's more interesting:
    Why should it be just 310V and not e.g. 312V? How was it calculated?
    And what is an "input" capacitor
  • #11 16362105
    mirex
    Help: 1950
    Rate: 1990
    At first, I also "looked" at the description of the components. Unusual with us.
    But then it made me wonder
    LisuuuPL wrote:
    17MB82S module
    And then I got to the description of the measurements and I renew my proposal. :)
  • #12 16362142
    lisek
    Service technician RTV
    Help: 6363
    Rate: 6894
    VESTEL 17IPS19-5 V.1 061112 / * barcode: 23128588 (white sticker)
    - MP3394
    - also Panel: VES315UNVL-01 / VES315WNDL-01 (LC320DXJ-SF E1 clone)
    Under VES315WNDL-01, VES315WNDA-01, LED strips (string)> there are two lines of 11_LED (3V) on the strip_line, min. behind Link
  • Output voltages to signal board measure correctly
    #13 16363255
    LisuuuPL
    A standby board in the sense of the one with a red indicator - probably infrared. Where you direct the remote control to change e.g. the channel. There are 5 pins, one is ground and the other four pins are + 5V
    LisuuuPL wrote:
    IC301 chip
    Sure - COSMO 1010 817 K30 E
    LisuuuPL wrote:
    IC301 - 11V COSMO 1010 817 K30 E
    IC200 - 20V COSMO 1010 817 K30 E
    IC302 - 1.5V COSMO 1010 817 K30 E
    What is this?
    Quotation:
    There is this LED. I mean what I wrote above. The one that gives red light when the TV is in standby mode, or green when it is turned on
    Added after 27 [minutes]:
    I have measured the output voltages to the signal board again and they are fine,
    He adds a picture of the voltages on ICs 301 200 302 Orion 32LBT731 TV, Vestel 17IPS19-5 power supply - no standby
  • #14 16363465
    mirex
    Help: 1950
    Rate: 1990
    And what about gentlemen, including moderators? Still believe that the topic deserves a presence on the forum?
    After all, this is a clear desecration of electronics. ;)
  • #15 16363474
    LisuuuPL
    Should I record a video with the measurements?
    Added after 21 [minutes]:
    https://www.youtube.com/watch?v=49yEzqhs0nc&feature=share
  • #16 16363979
    GanCegall
    Help: 339
    Rate: 1631
    Massacre, I vote for the basket. :-) And then "empty the trash"
  • #17 16363987
    LisuuuPL
    Topic in category "Beginning repairs"
    I don't know what to expect
  • #18 16364688
    arko100
    Admin of RTV group
    Help: 138
    Rate: 421
    I will forgive my colleague, but to repair a device, you should familiarize yourself with its operation and the functioning of individual components.
    Meanwhile, on the second day, my colleague writes about measurements on the IC200, IC301, IC302 systems, without even trying to find out what these systems are and what they are for.
    I would like to point out that my colleague is concerned with the tensions that are dangerous to health and life. In addition, a poorly repaired AC adapter can cause a fire.
    I am closing now.
The discussion revolves around troubleshooting an Orion 32LBT731 TV with a Vestel 17IPS19-5 power supply that is not entering standby mode. Initially, the TV was completely dead with a blown fuse (3.15A 250V). After replacing the fuse, the standby LED briefly illuminated before going out again. Various voltage readings were taken from the power supply and components, indicating that while some output voltages were correct, the standby LED remained off. Participants in the forum suggested checking the standby board, input capacitor voltages, and the integrity of diodes and NTC components. There were also discussions about the importance of understanding the function of each component before attempting repairs, highlighting safety concerns with high voltages.
