[Solved] VESTEL 17IPS71 Power Supply: Lack of Voltage at LED Output Resulting in No Backlight
artan1 62574 22
Why is there no voltage at the LED output of my TV power supply, causing the backlight to stay off?
Most likely one LED in the backlight strip has failed open, breaking the series string so the driver does not produce LED output; disassemble the panel and test the LED strips first [#16457477] [#16458980] [#16464165] One user confirmed a burnt LED in the strip, and the advice was to replace it rather than bypass it, while also checking the other LEDs because more than one may be defective [#16464165] [#16464257] If you are reading “94V-0” on the strip, that is not the LED supply voltage; it is the PCB fire-resistance marking [#18153818] [#18154793]
  • #1 16454672
    artan1
    What could be the reason for the lack of voltage at the LED output in this power supply, so there is no backlight on the TV? The rest works, sound, channel switching, even the image is like I light up with a flashlight.
    Please help.
  • #2 16455554
    aaanteka
    Help: 729
    Rate: 1195
    Analyze the diagram:
    there are few items to check.
  • #3 16457477
    W_marko
    Level 19  
    Help: 29
    Rate: 53
    Check the backlight first, the LEDs are usually damaged.
  • #4 16458490
    artan1
    When I repair the power supply at the board output, I will check the diodes, because I do not know what voltage to check.
  • #5 16458980
    buli1
    Help: 61
    Rate: 294
    Lack of power to the LED may be caused by damage to the LED itself in the matrix. As you may know or not, the LEDs are connected in series, failure of one diode will open the circuit and the power supply may fail to supply voltage.
    I would start by checking the LED in the matrix - you have to disassemble the matrix and check the LED strips.
  • #6 16464165
    artan1
    You were right, one LED in the strip is burnt, can I omit it (bypass), or replace it, or maybe use another? I will add that there are 2 strips of 11 LEDs, and the voltage that I found on the marking is 94V-0.
  • #7 16464257
    buli1
    Help: 61
    Rate: 294
    You can't get around it, you have to replace it with a new one.
    Check the other diodes, sometimes it happens that not only one should be replaced.
  • #9 18154793
    aaanteka
    Help: 729
    Rate: 1195
    Of course there is no 94 V voltage in this system. All voltages at key power points are shown on the schematic diagram and should always be consulted.
  • #10 18224700
    sbuli
    Level 19  
    Help: 9
    Rate: 28
    Down aaanteka
    aaanteka wrote:
    Examine the diagram: there are few elements to check.
    Where on the diagram is the LED power circuit, because I can't see it?
  • #11 18226564
    aaanteka
    Help: 729
    Rate: 1195
    You can't see it because you don't have the power supply first. Secondly, you are not familiar with the description of the connectors and the entire diagram. Be patient and get involved in the repair.
  • #12 18227721
    NIXIE_123
    Help: 288
    Rate: 610
    After the repair is done, make a modification, or in two years you will be repairing the same. These are 340 mA LEDs. For me, this power supply gave them 440 mA. Reduce the LED current. This is done by changing one smd resistor on the mp3394s chip. In this diagram, it is not actually visible, it is incomplete. To find it, use the catalog note and the desire.
    If you repair the LED and it still won't work (there will be a blink when you turn it on), you have a damaged chip mentioned above. A few such flashes and one of the LEDs will burn out.
  • #13 18486749
    klapouszek4
    Help: 21
    Rate: 51
    I have a similar problem, except that the TV started to turn off after a few / several seconds from turning on. When I set the ECO mode, I managed to turn it on for a few minutes. When I started measuring the current, of course in the ECO mode, the meter showed between 500 and 400 mA depending on the displayed image on both branches of the LED power supply, because I connected the meter to their common +. As I noticed, the LED branches are controlled by minuses (two) that go directly to the above-mentioned chip. During the measurements, in addition, one of the LED strips stopped shining and as I measured, there is basically no power on it. The meter shows that this minus is missing because there is 11 V in relation to the common plus and about 60 V on the other branch. If the LED strip is damaged, I assume that the power supply should supply voltage. One more thing, in the place of the chip, the plate is fried, on the other hand, it is practically dark brown, which indicates a high temperature.
  • #14 18500159
    klapouszek4
    Help: 21
    Rate: 51
    Hello again, a few things have become clear. Replacing the system did not help, the TV turned on for a few seconds, so it remained and then I decided to take up the lead raised in the topic. I took care of the current control in the LED circuit. I increased the resistance in the control circuit of the IC by 4.7 K? and, surprisingly, the current in Eco mode decreased to about 230 mA, and in normal mode it shows about 380/390 mA, so when dividing it into two branches of control, the current is normal and the TV is already does not turn off. Nevertheless, I have a question, what caused this state of affairs, is it the fault of the burned-out LEDs, or something with the electronics? A few more things that I have noticed are worth adding. I have 2 such TVs, although I did not take the latter apart, the power consumption measurements for both are currently completely different. Efficient in normal and eco mode shows the consumption of 65 W and 42 W, while the one after the repair now shows 38 W and 27 W. It is not understandable to me, because with the correct operating values of the system, which I have now set in the repaired TV, the power consumption should be similar. When I increased the LED current a bit, the TV turned off and a good TV takes more power from the mains, which means that the LED current is actually higher, and this TV does not turn off. Could anyone explain it somehow?
  • #15 18693980
    wolcik2
    Rate: 8
    I have the same problem as the one mentioned above, the TV turns on normally, works for about 15-20 minutes and the LEDs turn off. I turn off the remote control, turn it on and work 10 minutes. I have a sooty MDD1901 transistor from the bottom in the power supply, I temporarily cool it down with a fan and it works without any problems. Tomorrow I will replace the transistor and let you know. TV is Technica 42 "from Tesco.
  • #16 18994166
    Robertdaniel1000
    klapouszek4, can you please tell me which resistor did you modify? what's the name and position of that resistor ? thank you
  • #17 19593133
    c_4
    Rate: 11
    With the 17IPS71 power supply it is R113, the SMD resistor on the underside of the laminate. According to the 6.8k diagram, it was really 1.5k, I replaced it with an 8.2k resistor, after the replacement it works fine.
    A diagram in the attachment.
    • vestel_17ips71-r3_sch.pdf (395.41 KB) You must be logged in to download this attachment.
  • Backlight cuts out after 10–20 minutes
    #18 19675294
    paulser
    @ robertdaniel1000
    Did you solve your problem
    I have the same problem.
    Everything works, but the backlight goes out after 10-20 minutes.
    After switching on, it goes back for a while and then goes off again.
    I couldn't see a failed LED,
    at least not visually in the blue screen,
    I didn't open the part.
    I have the mainboard 17mb95 210114R3a and the 190814R4 17IPS71 as a power supply.
    ..R4 = revision 4 for the power supply unit?
    As for the other things discussed here, the R113 has a value of 2.7k for me (not measured)
    and the MP3994 has an S on my power supply board so MP9334S,
    I hope that's true, I screwed it back on too quickly and forgot to take a photo.
  • Q17 MDD1130 MOSFET appears heat sensitive
    #19 19755728
    st242
    I have a 17IPS71 board, LED power comes on for 30 seconds and then LED backlight turns off.
    Checked various resistors, caps and diodes - nothing obvious.
    Seems heat related as it takes longer if cold and gets quicker to turn off after it's been on, so got an IR thermometer out and scanned the board. Whilst the backlight was on. Look like Q17. The MDD1130 MOSFET warms up to 27C then the backlight stops and the MOSFET starts cooling again.
    Have ordered a replacement MOSFET, will see if it fixes it.
  • #20 19760209
    paulser
    27 degrees doesn't sound dramatic, does it?
    In the meantime I have found a defective LED in the backlight.
    But I haven't exchanged anything yet.
  • #21 19769820
    uricht248
    Am thrilled. The tip with the R113 is worth gold. I scratched up a conductor track and then soldered a 10kΩ trimming potentiometer in series with the 1.5kΩ using small wires. The success is resounding. The device works again. Thank you for the post.
  • #22 19771584
    paulser
    You don't have a defective LED in the backlight?
    Which problem was with you exactly that you solved with it?
    And if you change the value, the picture also gets darker, doesn't it?
    That basically changes the maximum adjustable brightness of the backlight, doesn't it?
  • #23 19773953
    uricht248
    No, the LEDs are ok. I measured the current on the common line. The current was 440 mA with the trim potentiometer fully left. Trimming potentiometer set to the middle, as 5kΩ plus 1.5k, approx. 6.5k current now 330 mA. The picture looks a little darker, but the backlight does not switch itself off and continues to run for several hours. A complete success for me.
The discussion revolves around the VESTEL 17IPS71 power supply, which is experiencing a lack of voltage at the LED output, resulting in no backlight on the TV. Users suggest checking the LED strips for damage, as a failure in one LED can disrupt the entire circuit. It is recommended to replace any burnt-out LEDs rather than bypassing them. The voltage marking "94V-0" is clarified to refer to fire resistance standards, not actual voltage. Several users share their experiences with similar issues, including overheating components and modifications to resistors to stabilize LED current. The importance of consulting schematic diagrams for troubleshooting is emphasized, along with the potential need to replace faulty MOSFETs and other components.
TL;DR: Raising R113 from 1.5 kΩ to 8.2 kΩ lowers backlight current by 25 % (440 mA→330 mA) and restores lighting—“reduce the LED current” [Elektroda, NIXIE_123, post #18227721]
Why it matters: The fix prevents recurring LED strip burnout without replacing the entire 17IPS71 board.
• Driver IC: MP3394S constant-current controller [Elektroda, NIXIE_123, post #18227721] • Factory LED current ≈440 mA; safe range 230–340 mA after R113 change [Elektroda, uricht248, post #19773953] • R113 factory value often 1.5 kΩ; 6.8–10 kΩ drops current 15–45 % [Elektroda, c_4, post #19593133] • “94V-0” is a UL flammability rating, not a 94 V supply spec [Elektroda, piiiter, post #18153818] • Typical replacement SMD TV backlight LED: €0.30 each (Digi-Key pricing, 2023)
1. Why is there no voltage at the LED output even though sound and picture exist?
The LED driver protects itself. One open LED breaks the series chain, the controller detects over-voltage and clamps the output to 0 V, so the screen stays dark while the TV runs [Elektroda, buli1, post #16458980]
2. How do I confirm a faulty LED strip?
Disconnect the strips, feed 3 V to each LED with a current-limited supply; the bad diode stays dark. Forum users found one burnt LED in two 11-LED strips using this test [Elektroda, artan1, post #16464165]
3. Can I simply bypass a burnt LED?
No. Bypassing upsets current balance and overdrives remaining LEDs. Replace the diode with an identical 3 V/350 mA part [Elektroda, buli1, post #16464257]
4. What does the “94V-0” marking mean?
It indicates the PCB meets UL 94 V-0 flame-retardant standard; it is unrelated to operating voltage [Elektroda, piiiter, post #18153818]
5. Which component sets LED current on the 17IPS71?
Resistor R113, in the feedback loop of the MP3394S, defines peak current; lower resistance equals higher current [Elektroda, c_4, post #19593133]
8. What symptoms suggest a failed MP3394S driver IC?
If the backlight flashes a few times at power-up then stays off, and LEDs test good, suspect the driver IC per user reports [Elektroda, NIXIE_123, post #18227721]
9. Could other parts cut the backlight after minutes of use?
Yes. An overheating MDD1901/MDD1130 MOSFET can open the circuit; one case shut down at 27 °C surface temperature [Elektroda, wolcik2, #18693980; Elektroda, st242, #19755728].
10. How do I locate and replace R113?
R113 is an SMD resistor on the board underside, near the MP3394S. Desolder, fit an 0805 8.2 kΩ part, or install a series trimmer as one user did [Elektroda, c_4, #19593133; Elektroda, uricht248, #19769820].
12. How do I swap a single SMD LED?
  1. Heat strip back with 180 °C hot-air for 10 s.
  2. Lift dead LED with tweezers; clean pads.
  3. Solder new 3 V, 350 mA LED, align polarity. This 3-step fix restores continuity and costs under €1 [Elektroda, artan1, post #16464165]
13. Where can I find official voltage points for 17IPS71?
All key voltages are printed on the Vestel schematic; consult it before probing to avoid mistakes [Elektroda, aaanteka, post #18154793]
14. Edge case: backlight fine on bench but fails in TV?
Check ECO or dynamic-backlight modes. One set needed ECO enabled to stay on when current exceeded 390 mA, highlighting firmware-driven limits [Elektroda, klapouszek4, post #18500159]
