Opel Astra J 2009-2015: Suspension Knocking on Uneven Roads - Replaced Components & Solutions
przemek cichocki 11466 2
  • #1 16361707
    przemek cichocki
    Rate: 27
    Hello, from the beginning of the purchase I struggle with the problem of hard knocks hanging. when I go on a smooth road, there is nothing knocking, the noise begins after driving on the cobblestones, transverse unevenness of the road, on a dirt road the same thing, breaks as if something was to fall apart. in the meantime I replaced front shock absorbers, stabilizer links, stabilizer rubbers, shock absorber bearing pads, new discs and pads. please advice.
  • #2 16361909
    drdrug
    Help: 25
    Rate: 178
    Pins, steering gear checked? Loose carriage or damaged sleeves in the carriage, sleds. And it's best to drive to the Diagnostic station so that they thoroughly sweep the car
  • #3 16362151
    alpha100f
    Rate: 28
    At 90% you have broken the wishbone bushings or looseness on the pins. I used to have it in a different car, but there were only knocks on the bumps and that was the reason.
