Accessing TX-42AS600E Service Menu: Shifting Image to Compensate Damaged Matrix
doctor77 3243 4
  • #1 16362261
    doctor77
    Good morning, I have this tv with a damaged matrix is poured at the right edge of the tv on the width of about 2cm so I can use the tv watch etc. If I can get a way to enter the service menu I would get rid of the option to lightly scale or move the image so that it goes beyond the area of damage? something like overscana in old tv. The TV set is generally written down as a loss so I'm not afraid if something goes wrong, I would not blame it, so I silently count on help with this input in the service menu if there are options regarding the position of the displayed image and can be move a pair of cm to the side. Accessing TX-42AS600E Service Menu: Shifting Image to Compensate Damaged Matrix
  • #2 16362272
    sosarek
    Help: 9320
    Rate: 15528
    You will not remove damage to the matrix by entering the service mode.
    Z
    Pka, Poznań, 60-850
  • #3 16362334
    doctor77
    I do not write anywhere that I want to repair the matrix damage, especially physical by entering the service menu, I mean only to move the displayed image out of the damage area so as to extinguish it, I can even tap it with black tape, but to move the image narrowly on the right side, i.e. change the image size slightly vertically and horizontally.
    lisek
    Service technician RTV
    Help: 6344
    Rate: 6873
    This was the model from March 2014. plate. mainboard (AS600 series)
    ps
    Similar TNP4G568 2A / TXN / A1ZRUB 50 "LCD Main Board for Panasonic TX-50AS500 / TX-39ASW504 Link
    - chassis KM26e
    SM Link_ tx-42as500e-chassis-km26e
    * for TX-42AS500E> T-con: P / N: 6870C-0480A
    • Panasonic-TX-32ASW504-Bedienungsanleitung.pdf (1.69 MB) You must be logged in to download this attachment.
  • #5 16363332
    doctor77
    Thank you very much for your help, I did not find the service option menu to move the screen a little or change the ratio, so either the aspect ratio will change to 14: 9 or leave 16: 9 and I will cover the broken screen with black insulation tape, like on TV on the plot it will be great anyway.
    Unless I have overlooked the option of changing the position of the displayed image somewhere.
