Xperia M4 Aqua: Full Network Coverage but Unable to Make or Receive Calls
krecik10 3156 4
  • #1 16363778
    krecik10
    Rate: 56
    I have a Xperia M4 Aqua with a strange fault, i.e. there is full range but the phone does not ring, searching for the network finds all networks without any problems, but when I try to call him, I still have mail, it is also impossible to make calls, soft changed, checked for two play and orange cards, but silence all the time.
  • #2 16363851
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Maybe blocked after IMEI by operator for not paying the subscription. Do you know the origin of the phone?
  • #3 16363902
    krecik10
    Rate: 56
    The phone is certainly not the left customer on the contract, as I try to call him all the time, I can call him once in 10 attempts and then the connection is normal, if I disconnect and after a while I try to get out of range, the same is with the codes, e.g. * 101 # sometimes displays the account status, but usually it looks for and pops up that the problem with the codes.
  • #4 16415972
    Ukene
    I have the same thing, nothing helped (uploading android from the beginning too) I finally switched to another phone. What's most interesting, the internet on the phone works.
  • #5 17542638
    renegat888
    Rate: 10
    Hello. Has anyone managed to fix the problem? For me, the range shows. Internet works over LTE. But you can neither make a call nor answer. Checked antenna cable also bottom plate. We also re-load Soft and the same. Best regards.
