Sony xperia m4 aqua will turn itself off and on, it won't work wifi.
justynka13210 3516 2
  • #1 16965949
    justynka13210
    I have a Sony xperia m4 aqua phone, the phone in February will be 2 years old. For some time it has lost wifi and either does not show any available or to work and be connected you need to turn on and turn off the phone, which sometimes results in the fact that it turns on after a few minutes only, it is also that the wifi is "hanging" or like moments of division shows that is connected but the internet does not work. If I turn on any application, e.g. instagram, facebook, then the phone turns itself off and on.
  • #2 16966729
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Initially restore the factory settings. But I'm afraid the CD is raining. A common malfunction in this model.
  • #3 16974746
    justynka13210
    Restoring factory settings, unfortunately, did not help, when it turns off the phone takes a lot of battery.
