Sony Xperia M4 Aqua (D2303) No Network Coverage: Network Registration Issue, Microphone & Sound
malutki112 7500 11
Why does my Sony Xperia M4 Aqua see available networks but refuse to register on them, while SMS still works and calls do not?
Your phone likely has either an antenna/radio hardware fault or an IMEI/network block, not a software problem. One suggestion was to replace the bottom plate under the loudspeaker, because that part may contain the damaged antenna section and can stop proper network operation [#16434498] Another answer said to check whether the phone is blocked by the operator by IMEI, especially if it is second-hand or from an unknown source [#16487868] It was also noted that damage to the antenna wire, transmitter, or a chipped bottom plate can cause the phone to see some networks but fail to register, and that it may work only on some bands like 3G or GSM 1800 while failing on LTE900/GSM900 [#16487868]
  • #1 16434428
    malutki112
    Rate: 22
    Hello, I have a problem with my Sony Xperia m4aqua namely the lack of coverage, it is impossible to call but when I enter the settings and I search for the network it finds available but I do not want to register, I exchanged softa but still the same as the reason? I will mention that if you ask him, he will send an SMS or receive it if someone writes it, but the microphone does not work and the sound is playing or is it somehow connected?
  • #2 16434477
    nutergsm
    Help: 1034
    Rate: 1666
    The phone was not flooded or flooded at times?
  • #3 16434489
    malutki112
    Rate: 22
    Well, that's what I do not know and probably never will :(
  • #4 16434498
    misiekmik
    Rate: 26
    Try to replace the bottom plate which is under the loudspeaker because there is something wrong with it.
  • #5 16434521
    malutki112
    Rate: 22
    it's just weird that it looks even in LTE but does not log into the network
  • #6 16434560
    misiekmik
    Rate: 26
    Whole antenna without damage ??
  • #7 16434575
    malutki112
    Rate: 22
    All and how much can this lower plate with antenna cost? Maybe there is a micro-crack and it does not work for that.
  • #8 16434584
    misiekmik
    Rate: 26
    I do not know. I did the same with Sony after replacing the plate with the antenna was ok
  • #9 16440835
    malutki112
    Rate: 22
    The replaced circuit and range has appeared but the connection can not be established
    Added after 2 [hours] 45 [minutes]:
    So any suggestions on where to look for the reason?
  • #10 16445414
    malutki112
    Rate: 22
    Hello M4 repaired in 80% range is possible to call but only on the settings of the manual search network Play (plus).
  • #11 16487868
    kowalelektronik
    Rate: 22
    What is the origin of the phone?
    Are you the first owner? Was it somewhere bought "olx", "on the housing estate from the level" ??
    This is probably the phone blocked by imei by the operator.
    There may also be damage to, for example, the antenna wire, the transmitter, something chipped on the bottom plate ...
    The fact that it works on the plus side may be due to the fact that the phone logs to it on 3G or GSM 1800. And on LTE900 or GSM 900 will not be.
    Greetings.
  • #12 16493534
    misiekmik
    Rate: 26
    Hello, I have a problem with my Sony Xperia m4aqua namely the lack of coverage, you can not call coverage is heya but you can not make a call on the GSM mode is full but you can not call or no one can call. But sms came
The discussion revolves around a Sony Xperia M4 Aqua (D2303) experiencing network registration issues, where the device can detect available networks but fails to connect, preventing calls despite receiving SMS. Users suggest potential causes including damage to the antenna, issues with the bottom plate under the loudspeaker, or possible IMEI blocking by the operator. The author mentions partial repair success, with the device able to connect manually to a specific network but still facing limitations. Further troubleshooting is recommended, focusing on hardware components like the antenna and circuit board.
