Renault Scenic 1 Lift - Replacing the Sirius 32 controller without losing the im
tomi1975 5964 13
Can I keep the immobilizer and my working keys by soldering the AM29F200 flash from my original Renault Sirius 32 ECU into a replacement controller, and do the ECU part numbers have to match?
Yes — the thread’s practical answer is to solder the flash from your original Sirius 32 into the replacement ECU, which should preserve the immobilizer and let the car start with your existing keys [#16197584] [#16197647] [#16218419] Several users say this is effectively a clone and is faster and cheaper than decoding the immobilizer [#16197584] [#16197647] The ECU numbers are best if they match, but one user reported moving memory between completely different Sirius 32 units without problems; the important thing is that it is the same Sirius 32 family, not Sirius 32N [#16197584] [#16198030] Another caveat mentioned is to match the air-conditioning version of the ECU if your car has that equipment [#16198119]
  • Soldering AM29F200 flash preserves immobilizer pairing with existing keys
    #1 16197053
    tomi1975
    Rate: 10
    Hello, in my Sirius 32 S110037000A controller, the pin 64 timing timing solenoid valve control has fallen (ground control), apparently not a profitable repair, so I have to buy another controller in which you need to decode immo. For me, the immo works without a problem, is it enough to solder the flash memory with this AM29F200 ... to have a working immo with my keys in the new driver (I have 2 working) from what I read it seems to work, and now I am faced with the dilemma of decoding immo or memory divider?
    The car has a 2.0 16v engine, other no. driver is: 8200028833, 7700110471
    which of these no. It is the most important?
  • #2 16197402
    sebap
    Help: 538
    Rate: 1082
    It is better not to buy a set, i.e. a driver, a loop and a key, and then transfer the electronics to your remote control from the key?
    invector
    Help: 24
    Rate: 103
    You just need to solder flash and everything should work. Certainly cheaper and faster. As for the driver numbers, it's best if they are the same, but I personally shifted memory from one driver to another with completely different numbers and I didn't notice anything wrong. The question is whether your driver is SYRIUS 32 or SYRIUS 32N?
  • #4 16197599
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Here, the loop is only a reader, if I remember, so the UCH can also be replaced.
    The memory replacement was triggered if the driver numbers are identical.
    You can do overwriting by editing the memory contents.
    15darekvw
    Help: 82
    Rate: 571
    I will say briefly solder or make a clone.
  • #6 16198030
    Pawel wawa
    Help: 1262
    Rate: 4433
    Who told you that? I'll probably fix it faster than it takes to remake the memory. If you buy a driver with the same numbers, it will be enough. After all, this is an ordinary Sirius 32, not 32N.
  • #7 16198101
    tomi1975
    Rate: 10
    It is a regular 32 without N Pawel wawa you know this fault, can you remove it? This is what the specialists said about what is announced on the internet, I called a few and nobody knows this fault. Will you undertake the repair or provide instructions?
  • #8 16198105
    tomasz0703
    Help: 69
    Rate: 489
    Why feel sorry for the comp max 100 irrespective of what numbers and flash the flash 15 minutes and after work and everything flashes in ori.
    Moderated By Pawel wawa:
    A friend writes nonsense. It does not matter with what numbers. It is true that it does not have to be the same, but not all numbers will match.
    l.jola
    Rate: 17
    I've been through this a few times already ... user DAMDAM did this to me, write PW to him. He transferred the Memory to another Sirius32 and smiga ... important as you look for a computer, it must be a version with air conditioning (if you have one in yours)
  • #10 16199084
    tomi1975
    Rate: 10
    It doesn't matter if it's manual or climatronic? I have a manual and there is a problem like after no. to recognize what equipment the car had?
  • #11 16199139
    daras41
    Help: 57
    Rate: 315
    Sirius 32 goes without a spout. I was doing Galletto boot mode ;)
  • #12 16199433
    tomasz0703
    Help: 69
    Rate: 489
    Even without boot mode it goes, I made 100 of them :) again, moderator Paweł Wawa is catching me for words, I think he caught on to me, maybe not indifferent to what numbers but most of them fit like a mower knows what and how (air-conditioning tachometer can without cana).
  • #13 16199982
    l.jola
    Rate: 17
    for sure ? can you read the whole thing? because apparently only a fragment .. and this is the one in which there is no immo code.
    you want to say that it will work from the version without air conditioning to the version with air conditioning? And after this treatment, the climate will even work?
  • Sirius 32 replacement works with transplanted immobilizer flash
    #14 16218419
    tomi1975
    Rate: 10
    Hello, yesterday I installed a new driver with soldered flash from my computer, everything works as in the original.
    Thanks to everyone for your help, because some car electronics experts in my area wanted PLN 400 for replacing the flash or cleaning it, and even in scrap yards, PLN 200-400 for the driver that can only be checked after removing the immo, is a big exaggeration.
    Fortunately, there is olx and the electrode ended up at PLN 70 and a little sweat when replacing the flash.
The discussion revolves around replacing the Sirius 32 controller in a Renault Scenic 1 without losing the immobilizer (immo) functionality. The original controller has a faulty pin related to the timing solenoid valve control, leading the user to consider purchasing a new controller. Several participants suggest that instead of buying a complete set (controller, loop, key), it is more efficient to solder the flash memory from the original controller to a new one. It is emphasized that as long as the controller numbers are compatible, the immo should function correctly after the memory transfer. The importance of ensuring the correct version of the controller (Sirius 32 vs. Sirius 32N) is also highlighted. Ultimately, the user successfully installed a new controller with the soldered flash, achieving full functionality at a significantly lower cost than local repair services.
