NAVITEL R600 The battery does not maintain the camera settings
zajmox 39708 16
Why does the NAVITEL R600 lose its date and time settings shortly after the car power is switched off?
The NAVITEL R600 should keep its date/time settings after power-off; if it resets, the built-in battery or the unit itself is likely faulty, and the recommended fix is to complain under warranty to the seller or manufacturer [#16477076] The internal battery is only meant to keep the camera alive for a few minutes so it can shut down properly, not to work like a UPS [#16369069] One user reported that a later unit worked correctly, while an older December 2016 unit kept returning to the default date (1.1.2016), which also caused old recordings to be deleted first because they got the oldest timestamp [#16477076]
  • #1 16366700
    zajmox
    Rate: 16
    NAVITEL R600 The battery does not maintain the camera settings. After a few moments from switching off the engine (power supply), the camera loses the date settings, etc.
    Does anyone have similar problems?
  • #2 16366941
    jaga134
    Help: 88
    Rate: 192
    Forgive me if I ask a silly question. Do you have a power cord connected to the base of the camera or directly from the side to the camera? If the battery base is located on the base, the battery is apparently not being charged.
  • #3 16367257
    zajmox
    Rate: 16
    of course for fixing. So it is a battery. I wonder how should I discard and advertise it now?
  • #4 16367355
    jaga134
    Help: 88
    Rate: 192
    This morning I peeled off the stand from the windscreen of the car. It can be peeled off only, you need to put something, preferably not metal between the stand and the glass. You can also "cut off" the stand from the glass using a fishing line.
  • #5 16368496
    zajmox
    Rate: 16
    Do you have the same problem as me? (with battery) I was in the living room this morning where I bought a question about the complaint process, they directed me to the Nawi website to advertise directly with the producer.
    Added after 27 [minutes]:
    You do not need to peel off! It will be able to disassemble the battery without peeling off the glass!
  • #6 16368620
    jaga134
    Help: 88
    Rate: 192
    No. I just attached the camera too close to the rear view mirror, so I could not slide it out of the stand. Now it's ok
  • #7 16368636
    zajmox
    Rate: 16
    So everything works well for you? How long does the battery last?
  • #8 16369069
    jaga134
    Help: 88
    Rate: 192
    Yes. Works correctly. How long does the battery last? It's hard to say because I did not check it but I think it will work for a few minutes. Aku with a capacity of 200mAh is not a battery to work just like UPS to properly shut down the system. But in the case of a webcam you can use the power bank.
  • #9 16369903
    zajmox
    Rate: 16
    And you do not erase the time, date, etc. settings? After switching off the engine (power supply)
  • #10 16371103
    jaga134
    Help: 88
    Rate: 192
    No. Nothing is deleted. Tomorrow I will change the hour / durnowaty / summer time. I will see what the effects will be.
  • #11 16373284
    jaga134
    Help: 88
    Rate: 192
    I changed the hour. Nothing has been deleted.
  • #12 16373408
    zajmox
    Rate: 16
    Cool. I have bad luck . Tomorrow I am sending you to the website.
  • #13 16448142
    jaga134
    Help: 88
    Rate: 192
    Plug the USB cable from the side to the camera. Eyes
    Insert the other end of the cable into the PC or laptop. Some information should appear on the webcam's screen. The first one highlighted in another color is "mass memory". Approve it with the ok key and already. You read in a computer like a flash card. However, at the beginning, replace the USB cable with a different one. I had a lot of cases, that the cable / efficient / in one device was working and in the other it was not.
  • #14 16477076
    pcichomski
    Help: 32
    Rate: 96
    I have an identical problem. The manufacturer claims that you should take the camera from the car with the holder (!), Because there is a battery there. But .... a friend bought the same camera in May 2017 and there is no problem with it. I contacted the producer again and said that they improved something and now he supports me, but I have an old version (from December 2016) and I am not entitled to an exchange. I advertise with the warranty at the seller, let him "buja" with the producer. According to me, two identical cameras can not work differently, and the producer tries to shirk.
    Please note the important thing. If the memory card is full if you do not set the clock and after removing the camera will return to the initial settings (at me 1.1.2016), the next videos will be erased immediately because they have (!) The oldest date. I realized just when it turned out that I did not have an evidence film, and all the films I had from a few months ago.
    I recommend stubbornly advertising at the manufacturer or seller, because not all copies have it.
    Greetings.
  • #15 16477674
    jaga134
    Help: 88
    Rate: 192
    I bought the camera in March this year. For now I am using a 16 GB card. When transferring recordings to a laptop, I use either a USB cable from the Canon camera without taking the camera out of the glass. Ie. I do it in the car or I pull the camera out of the holder with the battery and transfer the recordings to the PC at home. The camera so far has not caused me any surprise. I have not tried to block the shot yet. The card is always recorded and erases the older recordings. Unfortunately, 16 GB of the card is enough for about 50 km drive, therefore driving further than 50 km in one direction I have only the registration of return on the card.
  • #16 16663001
    Rodaivuk
    Hello. Today I just returned to the store, bought a few days early R600kę. It could not be turned on any more than the screen with the Navitel logo. Until then, I'm not discouraged and I'm waiting for the second one, the same :)
  • #17 17130777
    KoniecznyPawel
    I also had a problem with resetting settings, but I just gave up this webcam after unsuccessful attempts to file a complaint with Navitel.
The NAVITEL R600 camera is experiencing issues with the battery not retaining settings such as date and time after the power supply is turned off. Users have discussed potential causes, including improper power connections and battery malfunctions. Some users reported that their cameras function correctly without losing settings, while others with older models faced persistent issues. Recommendations include ensuring proper power connections and considering warranty claims for defective units. Users also noted the importance of memory card management, as full cards can lead to loss of recorded footage if the date settings are not maintained.
