[Solved] Playstation 4: Comparing Original and Slim Console WiFi Speeds - Download Rate Discrepancy
Muti1987 16107 6
  • #1 16367675
    Muti1987
    Rate: 59
    Hello, I have two PS4 consoles, one purchased on the day of the premiere connected to the Internet via wifi on the connectivity test shows a download of 9.8 mb / s, a new one which I bought in a slim version that stands exactly in the same place max 500 kb / s (and sometimes drops to 9kb / s which makes doing anything in the ps store impossible). What could be the reason ? I reset the router and it did not help, DNS settings did not help either.
  • #2 16368953
    MarcuzMB
    Maybe try to connect with a cable? And do the test.
  • #3 16370181
    Muti1987
    Rate: 59
    I wanted to do as you wrote and I moved consoles to the other room where there is a router. I connected everything and checked through wifi. Everything works download has jumped on 19 mb / s. The distance between the old place and the new one is about 8m on a straight line with one wall. I am surprised by this difference. Can this suggest damage to the wifi module in the console? Will signal amplifiers help? I would rule out the Router because I live on the second floor, I can leave the house and walk away about 30m from the block (the router is on the other side of the block) and it catches my range on the phone.
  • #5 16370476
    Muti1987
    Rate: 59
    I managed to find a Ufff solution ... I borrowed (I already purchased) Linksys RE1000 which I connected wirelessly with Wi-Fi while PS4 connected to Linksys wired. On the console I set the wired Internet and oscillates within 10mb / s downloading upload 1 mb / s.
  • Wired Ethernet is the only reliable PS4 NAS connection
    #6 16378648
    arnoldziq
    Help: 789
    Rate: 300
    I watch a lot of movies from the NAS through PS4. The time it takes to read files via WiFI is embarrassing. Often the files are not read and PS4 returns a message that the file is damaged.
    Watching family pics is a real nightmare (especially with the amount I keep).
    The cable is the only safe solution.
    I have (it seems to me) quite a good Mikrotik 2011UiAS-2HnD-IN router. It is true that the floor is higher than the PS4, but the distance is about 4.5 -5 meters. WiFi in PS4 is a gamble.
  • #7 17119530
    Muti1987
    Rate: 59
    After a few months of testing, I can safely say that the amplifier did the job. I recommend it to everyone who plays online games without any problems
The discussion centers around the WiFi speed discrepancies between an original PlayStation 4 and a PlayStation 4 Slim. The original console achieves a download speed of 9.8 Mbps, while the Slim version struggles with speeds as low as 500 Kbps. Users suggest troubleshooting steps such as connecting via Ethernet, relocating the consoles closer to the router, and considering the potential for hardware issues with the Slim's WiFi module. One user reports improved speeds after using a Linksys RE1000 WiFi extender, achieving around 10 Mbps. Others emphasize the reliability of wired connections over WiFi for streaming and gaming, citing poor performance with the PS4's WiFi capabilities.
