Upgrading Lenovo g580 Laptop's Intel Celeron B830 1.80GHz to i5-3210m for CS: GO Gaming
adekbp 5946 6
  • #1 16368560
    adekbp
    I want to ask you if it makes sense to replace the processor with Intel Celeron B830 1.80GHz for i5-3210m. I want to replace the processor because I want to play CS: GO, unfortunately it is not possible on this processor. Fps drops to 20, max fps is around 60 but very rarely, generally lacking fluidity. But before buying this prock, I wanted to ask you whether it is possible and whether other components will work together, and whether the performance of this processor will change anything at all. I read that CS: GO is a typical FPS player, so better indicated. I would like to achieve 90-120fps, or rather that this game should run smoothly. I also have concerns whether my bios will handle this processor.
    Laptop technical specification:
    Windows 7 Proffesional SP1 x64
    Intel Celeron B830 1.8GHz
    RAM: 6GB
    Graphics: Nvidia Geforce GT610m 1GB and Intel HD Graphics
    And the motherboard (I'm providing information from the Speccy program):
    Motherboard
    Manufacturer LENOVO
    Model Product Name (U3E1)
    Version Mainboard version
    Vendor Intel chipset
    Model Sandy Bridge chipset
    Revision 09 chipset
    Southbridge Vendor Intel
    Southbridge Model HM76
    Southbridge Revision 04
    BIOS
    Brand LENOVO
    Version 5ECN36WW (V3.02)
    Date 2012-08-06
    Thank you in advance for your response!
  • #2 16368629
    enhanced
    Help: 964
    Rate: 884
    As the hm76 chipset, you can safely insert the i5 - you may need a new, more powerful power supply.
    How many watt do you currently have?
    And with this graphics, I do not know if you will achieve the amount of FPS you dream about - the cpu fact must be replaced, but then it can very quickly block the performance of this NVIDIA "integrated" :)
  • #3 16368644
    adekbp
    I don't have to play high :P At most, I will change the settings to lower ones, I do not care so much about quality, but about liquidity. Anyway, there is a dedicated GT610m card with up to 1 GB of virtual memory :P How to check this power supply? Need to remove the housing?
  • #4 16368692
    enhanced
    Help: 964
    Rate: 884
    I wrote about this "integrated" 610m :)
    You have a sticker on the power supply after all - there is voltage and current and this is multiplied by watts - so enter how many V and A you have on the current power supply.
  • #5 16368774
    adekbp
    20v 4.5A, these are the parameters on the power supply
  • #6 16368790
    enhanced
    Help: 964
    Rate: 884
    And that should be enough - but you will find it alive when he plays on the i5.
  • #7 16368791
    lisek
    Service technician RTV
    Help: 6357
    Rate: 6888
    Z forum Lenovo o upgrade Celeron B830 na tej mb Link
    *cpu z max.TDP 35W
    Jeśli masz HM70 to tylko Pentium/ i Celeron.
    Podaj pełną nazwę modelu laptopa
    Wszystko o serii G580 (Intel) Link_ support G580
    p.s
    Np.
    G580 20157
    Intel Core i5 3210M
    RAM 8.00GB Single-Channel DDR3
    Motherboard LENOVO Emerald Lake 2 (CPU Socket - U3E1)
    This system was shipped with the following motherboards :
    LG58 MB UMA W/BT/HDMI WO/3G (G580) FRU: 90000312
    * LG4858 11252-1, HM76, KB9012
    QIWG6 MB DIS N13P-GL 2G 100M W/HDMI (G580/G585) FRU:90000117
    QIWG6 MB DIS N13M-GE 1G 100M W/HDMI (G580/G585) FRU:90000118
    QIWG6 MB UMA 100M W/HDMI (G580/G585) FRU:9000011
    In order to confirm which one would be the correct FRU, you need to take your serial number and run it on the support site: Link_ partslookup
    Read other on Link_ G580 Maintenance
    Manual
    Lenovo G580 model ( 2689 )
    i3 -3110M (SR0T4) , 6GB RAM / MB: LA-7981P rev. 1.0 (QIQG5_G6_G9.)
    * CPU i5-3320M *Turbo nie pracuje), tylko nominalna 2.6GHz
    * 255 error
    Lenovo G580 (20150)
    * i5-3210m
    * BIOS Version : 5ECN33WW(V2.03)
    Bios update z 18.08/2013 G580 models:( 2689, 20157)
    Link
The discussion revolves around upgrading a Lenovo G580 laptop from an Intel Celeron B830 1.80GHz processor to an Intel i5-3210M to improve gaming performance in CS: GO. Users express concerns about compatibility with the HM76 chipset, power supply requirements, and potential performance bottlenecks due to the Nvidia GeForce GT610M graphics card. The original poster seeks to achieve smoother gameplay with 90-120 FPS, while others provide insights on power supply specifications and motherboard compatibility. BIOS updates and specific model numbers are also mentioned as critical factors for a successful upgrade.
