Lenovo G580 Laptop: Intel i5-430M PGA988/G1 Socket Processor Replacement Guide
Yagiel 15213 18
Can I replace the CPU in a Lenovo G580 with an Intel Core i5-430M, and is matching socket/TDP enough to guarantee compatibility?
No — the Intel Core i5-430M is a 1st-generation CPU and is not a compatible drop-in replacement for this Lenovo G580; you also need to match the motherboard chipset, not just the socket and TDP [#16207993] The G580 variants discussed here use HM75/HM76 chipsets, which support 2nd/3rd generation processors, and a BIOS update may be needed for some CPUs [#16208686] Reported working upgrades include i3-2370M and Lenovo-listed supported CPUs such as i5-3210M, while one user confirmed that i5-430M did not work in the G580 [#16212815][#16641631]
  • #1 16207923
    Yagiel
    A short and simple question, I'm about to replace the processor.
    Lenovo G580 laptop.
    Replacement for processor: Intel i5-430M socet PGA988 / G1
    I checked the stand and it agrees, I checked the TDP and it is the same, which means that I can confidently order it?
    Do I need to know anything else?
    Thank you in advance for your help and have a nice evening. :)
  • #2 16207973
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    Lenovo G580 laptop
    Laptop models in this series have been on several boards .........
    1. Write descriptions from the CD!
    2. What chipset!
    3. What processor did you have so far ?!
  • #3 16207983
    Przemko21
    Help: 110
    Rate: 307
    Lenovo G580 laptop
    These models usually have i3-3120M or Intel B960
    This model of the i3-3120M processor is more efficient than the i5-430M and comparable with the performance of the B960 so I do not know why you want to replace them.
    The processor stand is one and the chipset is the other. Provide the chipset to be sure
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8290
    Various processors were installed in these laptops:
    Anyway, the first generation I5 will definitely not fit.
    HM75 or HM76 chipset according to the service manual.
  • #5 16208428
    Yagiel
    Lenovo G580 15.6 inch laptop - Blue (Intel Celeron B820 1.7GHz, 6Gb RAM, 750Gb HDD, DVDRW, LAN, WLAN, Webcam, Integrated Graphics, Windows 7 Home Premium 64-bit)
    Exactly this laptop, some Celeron single-core processor, so it breaks down.
    And what is the name of this site where is the compatibility of processors?
    2 questions in that case what processor do you recommend for this configuration?
    Added after 16 [minutes]:
    http://www.cpu-world.com/Sockets/Socket%20G2%20%28rPGA988B%29.html
    Will every processor listed on this page that has a TDP equal to the current processor be functional?
  • #6 16208467
    lisek
    Help: 6350
    Rate: 6880
    Celeron B820 1.7Ghz / TDP = 35W it dual-core , but the weakest in this Sandy Bridge series
    * graphics should be GF610M (64-bit) * or similar
    - HM76 chipset Link_ list of compatible 3th generation CPUs
    * probably can be inserted from the Core i3 / i5 / i7 series (2xxxM)
    Pentium 2020M or i3 2348M / i3 3120M / i5 3230M /
    Use Aida 64, read the disc and chipset data and enter.
    Or enter number> e.g.
    Lenovo G580 ( 59337073 ) with Celeron B820.
    Bios upgrade needed (latest version) Link_ from the Lenovo forum
    If HM76 is 99% it is a CD on the platform
    Wistron LG4858 (11252-1)
    dt1
    Help: 7315
    Rate: 8290
    Most processors from the table that I have inserted should work. You may need a BIOS update, although the HM7x series chipsets were designed for 3rd generation processors, so they should rather be supported even in older versions.
  • #8 16212120
    Yagiel
    Socket 998B rPGA
    HM 76 chipset
    Motherboard Emerald Lake 2
    3rd generation will work, but I care about the second, can it?
  • #9 16212540
    iron64
    Help: 648
    Rate: 313
    Why? 3rd generation is better.
  • #10 16212634
    lisek
    Help: 6350
    Rate: 6880
    G580 when changing Celeron B830> to Core i5-3230m, motherboard Emerald Lake 2, HM76 chipset will work Intel AThief ... that is after 30 "min power will be turned off> OFF.
    CPU compatible link
    The cooling system is under the 2nd generation cpu.
    Most efficiently fits i5- 24?? - (Sandy Bridge)
    * i3-2328M CPU @ 2.20GHz / BIOS LENOVO 44CN45WW
    * 62CN34WW
    - i7- .. not really, the DC-DC cooling and supply system is not provided for them
    read with understanding, do not try to Link_ forums.lenovo
    Apart from the CPU, graphics performance (soldered into the board) has a significant impact on performance (e.g. in games)> e.g. NV410M
    or
    In a more powerful CPU> "stronger_ better" embedded graphics> new drivers, ....
    There is no major difference between i3 and i5 >> except you have Turboboost on the i5
    * when do you use it?
    * how does this relate to the cpu purchase price?
    sometimes the purchase price will exceed the value of the laptop ( ' :D ')
    ** aaha the issue of built-in RAM controller 1333MHz (Sandy), against 1600 (Ivy)
    The rest in the guide under this series from Lenovo link
    ________________
    look link
  • #11 16212746
    Yagiel
    2nd generation because it is about money, besides they are on quite nice performance.
    I prefer i5 than i3 because i5 has 2 cores and 4 threads and I care about it.
    That's why, as you say Lisek, I'll take an Intel i5-2430M SR04W 3.0GHz 35W TDP processor
    If you can confirm if it would be fully compatible then I would be grateful.
    I will use the laptop to mix music on Serato DJ. Unfortunately, the current processor works, but every 10 seconds there is a switch (unacceptable) and cuts off again. I doubt that RAM is 6GB. I would have to check the use of this and that while working on Serato. In total, he will be taken for 18-year-olds and proms so I care about stability (turboboost will be useful, but no picking up)
    This is not playing equipment.
    Of course, later I buy a macbook pro but so far no funds hence this processor replacement. So i5-2430M will do its job?
  • #12 16212805
    lisek
    Help: 6350
    Rate: 6880
    i5-2430M (Sandy Bridge) was on Lenovo Z570
    - HuronRiver Platform / LENOVO Emerald Lake chipset HM65
    - LTN156AT16L01 matrix
    The V370 model on the same platform was on the i3-2330M CPU @ 2.20GHz
    Model V570> the same platform> 2nd Gen Intel i5-2430M
    _________________
    AIDA64 will show e.g. Lenovo 20157 model
    CPU-Z will show e.g. Lenovo Emerald Lake 2
    will show Bios Phoenix EFI, ver. 62CN34WW, 04/26/2012
  • #13 16212815
    Yagiel
    Quote the official statement on Lenovo
    "Hi
    Welcome to the community.
    Please find below the supported Processor of your system, you can use any one of them.
    3rd generation Intel Core i5-3210M
    2nd generation Intel Core i3-2370M
    Intel Celeron B820 (1.60GHz, 2MB) "
    They are certain according to them and this 3210M is also at a nice price :D
    What do you think
    Of course, we are talking about stimulants and this is for 90 PLN ;)
  • #14 16212817
    enhanced
    Help: 963
    Rate: 883
    complicated answers
    7x chipset supports 3gen and 2gen but it is better to take newer.
    edit
    I was just surprised what you want 2gen or 3gen for a similar price.
  • #15 16212879
    Yagiel
    So 3210M order so? :D
    enhanced
    Help: 963
    Rate: 883
    Do you have another way? Only a quad but it's already 300+ zeta.
    Are you sure these scraps are Prock's fault? does not mean temperature or something else?
    Of course, the replacement is still recommended for pentiums.
  • #17 16212909
    Yagiel
    No exchange is recommended anyway because there is a gap between this processor and 6GB of RAM.
    After replacing the processor, the paste will be new Windows will be put up so everything will be fine ;)
  • #18 16641631
    krysztek
    I put it in: i3-2370M http://www.cpu-world.com/sspec/SR/SR0DP.html and it works
    I was still checking the SR07V also worked but i5-430m did not want to but it was possible that he was released because I had it on the site.
    Laptop to G580 Laptop (Lenovo)
    Serial number
    CB27773061
  • #19 16641789
    Yagiel
    Thank you for your help, I installed this cheap i5 and the performance has increased significantly, best regards!
The discussion revolves around replacing the Intel i5-430M processor in a Lenovo G580 laptop. Users emphasize the importance of verifying chipset compatibility, specifically the HM75 or HM76 chipsets, and the necessity of a BIOS update for certain processor upgrades. Various processors were suggested, including the i3-3120M, i5-2430M, and i5-3210M, with a consensus that newer generation processors (3rd generation) are preferable due to better performance. Users also shared experiences with processor installations, confirming that certain models worked while others did not. The conversation highlights the need for careful consideration of TDP and compatibility before making a purchase.
