Passat b6 2006 2.0TDI - No lights come on when the key is inserted
danielsowa29 31857 15
Why do no dashboard lights come on when I insert the key in a Passat B6, even after replacing the steering-column ignition lock/reader and trying another key?
The fault is likely not the ignition switch itself; the thread points more toward a power-supply, ground, gateway, or steering-column module problem, so the car needs proper diagnostics rather than more parts swapping [#16998972][#17004087][#17006424] Start by scanning all controllers with VCDS/VCP, checking which modules communicate and whether the gateway sees the key in the ignition slot [#17004087][#17006424] Inspect all fuses and grounds, especially the engine-compartment fuse/relay box and terminal 15 supply, because a missing supply after ignition can stop the dash from waking up [#16998972][#17006424] One reply also suggests the module under the steering wheel/column as a likely suspect in a similar case [#17004087][#17006424] Since the car still reacts to opening the door and the lights/radio work, the general power feed is at least partly alive, so the next step is diagnosis of the key reader/steering-column electronics and wiring, not another used ignition lock [#17005443][#17080520]
  • #1 16998748
    danielsowa29
    Rate: 19
    Hello, as in the subject, after inserting the key, no indicator lights on the dashboard ...
    As I read in the forum, I bought a repair kit and replaced it in the steering column, and still after the exchange nothing reacts ...
    I opened the ignition switch and a red LED is lit in it, but I found nothing more about the ignition switches on the Internet.
    What would be so problematic about him that the key still does not respond
    Thanks in advance for your reply
  • #2 16998816
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    A key from this car? Battery ok?
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    If this lock falls after inserting the key into the slot, one light will come on.
    You don't light up, so long as the original key is not dead.
    Installation first to check and key slot.
  • #4 16998964
    danielsowa29
    Rate: 19
    I've had it for over half a year and both keys don't respond
    battery certainly matters, because I exchanged from another car and also no reaction ...
    do you think the ignition should be checked? and if it is not the ignition, what would be another key ingredient in such a sudden failure?
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    It sounds strange but this type has it :-(
    This lock on the gear you changed was original packed in an unpacked box? They are intended for firing only once to encode to ecu, the used one is not bet because it will not work, then it must be overtaken by the electronics.
    Review all masses and fuses.
    In the engine compartment you have a box with fuses and relays.
    There is one big transmitter with two wide feet.
    Short them with each other, when the blower starts to work and some of the controls, give the car to the electronics, because you will only harm him more.
    After external contacts, nothing will work, there is a problem somewhere with the power supply or mass.
    Powodzonka
    DoctorCar
    Level 19  
    Help: 37
    Rate: 121
    Computer diagnostics and checking even without the key which modules speak in GATEWAY.
    Does the car react when the door is opened?
    Do the lights work?
    Emergency ?
    I shoot, but I think you get the module under the steering wheel, because I once had something similar
  • #7 17005443
    danielsowa29
    Rate: 19
    yes the car reacts to opening the door, the lights are on the radio plays, only with the brake applied and now it will not let go ....
    I bought a used ignition switch and even it doesn't respond ...
    the mechanic who was with me said that without ignition it won't work because it won't connect to the computer ....
    what module are you talking about?
  • #8 17005452
    Pawel wawa
    Help: 1262
    Rate: 4423
    Look for another one because it's a pity to read. Used ignition, you can put it in Passat b3, not here.
  • #9 17006059
    DoctorCar
    Level 19  
    Help: 37
    Rate: 121
    Not all modules need ignition to diagnose them - it's true, find a better one. As for the ignition is just a key reader and you can translate from another car.
    So it's not bad, m. Comfort and central electricity live
  • #10 17006074
    Pawel wawa
    Help: 1262
    Rate: 4423
    DoctorCar wrote:
    key reader
    On its own, including the core, it does not turn on the power supply, moreover it can be diagnosed without a key. At least parameters can be seen if there is communication or a recognized key.
  • #11 17006424
    DoctorCar
    Level 19  
    Help: 37
    Rate: 121
    The easiest way is to VCDS or VCP and do a driver scan and see which ones match. The power supply after ignition is easy to start by putting it on the fuses of the terminal 15. Generally to check the Gateway power supply and whether it is OK, then the module under the steering wheel, the tester check if he sees the key in the ignition slot
  • #12 17074480
    danielsowa29
    Rate: 19
    And I have a question, does anyone know where the comfort module is located in the Passat b6?
    modules only pop up on the net, not where they are located
  • #13 17074543
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    Behind the glove compartment.
    This is a set with immo so there is no way to change unless the whole set.
  • #14 17074648
    danielsowa29
    Rate: 19
    I bought the comfort module itself, and wanted to replace it because of what I read and say to people that it can be a problem of a non-responsive ignition,
    so you can't replace the comfort module itself?
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    There does not have to be a set in newer models, the set also has to be abs and next year there will probably be valves in the wheels in the set with immo ;-)
    Return the car to the electronics, you lose only time and money and the car stands and loses its value.
    Look also on the net are services where you can send ecu and do immo off but the problem is not known if you are holding immo because it should check the electronics and you can not do it online :-(
  • #16 17080520
    DoctorCar
    Level 19  
    Help: 37
    Rate: 121
    No information from computer diagnostics of controllers of their real parameters. No one will help here without this basic information, but this is not the way to such an unusual fault
✨ The discussion revolves around a 2006 Volkswagen Passat B6 2.0 TDI experiencing a complete lack of dashboard indicator lights upon key insertion. The user replaced the ignition switch and steering column components but still faced issues. Responses suggest checking the original key's battery, verifying the ignition switch's functionality, and ensuring proper connections and fuses. Some users recommend computer diagnostics to identify module communication issues, particularly with the comfort module located behind the glove compartment. The importance of using compatible parts and the potential need for ECU reprogramming are also highlighted.
TL;DR: Passat B6 no-lights-on-key-in faults often trace to power/communication: “one light will come on” when the lock drops, yet here 1 light shows 0 activity. “Installation first to check.” [Elektroda, diodabg, post #16998866]
Why it matters: This FAQ helps DIYers and techs quickly isolate power, key-reader, Gateway, or comfort-module faults without guesswork.
Why do no dashboard lights come on when I insert the key?
Loss of ignition-switched power (Terminal 15), a silent Gateway, or a non-encoded steering lock can prevent wake-up. Start by scanning the Gateway, then verify fuses and grounds before replacing parts. If the lock truly drops, at least one light should appear. [Elektroda, diodabg, post #16998866]
Does the key fob battery matter for this symptom?
A dead fob battery affects remote locking, not the immobilizer transponder. Still, confirm you’re using a correct key for the car and that the car battery is charged. A responder first asked: “A key from this car? Battery ok?” So verify basics before deeper diagnosis. [Elektroda, T5, post #16998816]
Can I diagnose a Passat B6 without the ignition turning on?
Yes. “Not all modules need ignition to diagnose them.” Use a scan tool to see which controllers respond and read parameters. This helps confirm if the Gateway and comfort electronics are alive despite no ignition. [Elektroda, DoctorCar, post #17006059]
What should happen if the steering lock/ignition reader engages correctly?
When the lock drops with a valid key, one warning lamp should light. If nothing lights, check the original key state, the key slot, fuses, and wiring before assuming module failure. [Elektroda, diodabg, post #16998866]
Where is the comfort module on a Passat B6 (2006) and can I just replace it?
It sits behind the glovebox and is tied to immobilizer functions. Swapping only the comfort module without proper matching often fails. Plan diagnostics and coding rather than plug-and-pray replacement. [Elektroda, diodabg, post #17074543]
Can I install a used ignition/steering lock from another Passat?
No. On B6, used units are not simple drop-ins. They need matching or rework; otherwise the car stays silent. As one expert noted, used ignition belongs in older models, “not here.” [Elektroda, Pawel wawa, post #17005452]
How do I perform a safe, quick power-path test (Terminal 15)?
Use VCDS/VCP to scan controllers. For power, you can temporarily feed Terminal 15 at the fuse panel to wake modules for testing. Then check if the tester sees the key in the slot. Stop if you lack equipment. [Elektroda, DoctorCar, post #17006424]
What is the Gateway module and why scan it first?
The Gateway routes communication between controllers. A scan reveals which modules “speak,” even with ignition issues. If Gateway power is good yet many nodes are silent, trace power/ground to those circuits. [Elektroda, DoctorCar, post #17006424]
My doors, radio, and lights work, but the ignition is dead. What next?
Comfort and central electrics can be alive while Terminal 15 stays down. Run a controller scan, verify Gateway power, then test Terminal 15 at fuses. This separates power delivery faults from reader/lock problems. [Elektroda, DoctorCar, post #17006059]
Is immobilizer the cause when the key won’t wake the car?
Maybe, but confirm with diagnostics first. Services can “immo off” at the ECU, yet that may not address a power-path fault. Fix supply and communication first, then assess immobilizer state. [Elektroda, diodabg, post #17075028]
What simple checks should I do before replacing modules?
Inspect main grounds, all fuses, and the engine-bay relay box. A large relay with two wide legs can be bridged briefly to confirm blower and controls wake. If they do, hand it to an electronics specialist. [Elektroda, diodabg, post #16998972]
How many failed keys point to a car-side fault instead of the key?
If two known keys both fail to wake the car (2/2), focus on vehicle power, reader, or communication. This strongly indicates a car-side issue, not just a bad key. [Elektroda, danielsowa29, post #16998964]
Is a brand-new steering lock required on this platform?
Yes. The gear-style lock is designed to pair once. Used locks won’t operate unless their electronics are reworked. Attempting swaps without proper tools wastes time and money. [Elektroda, diodabg, post #16998972]
Can a mechanic connect a scanner if the ignition won’t switch on?
A capable mechanic can. Some modules respond on the diagnostic bus without ignition. They can report real parameters and key recognition state. “It can be diagnosed without a key.” [Elektroda, Pawel wawa, post #17006074]
Quick 3-step: how do I triage a no-lights, key-in Passat B6?
  1. Scan the Gateway with VCDS/VCP and note which controllers respond.
  2. Verify Gateway power and grounds; inspect fuses.
  3. Briefly supply Terminal 15 at the fuse panel to see if modules wake, then re-scan. [Elektroda, DoctorCar, post #17006424]
