Choosing a BIOS Programmer: Comparing TL866CS, EZP2013, and CH341A for Laptop Motherboards
wentyl215 11559 4
  • #1 16370782
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    I need to buy a Biosu programmer primarily for the bones of motherboards in laptops. Of course, to make its scope as large / universal as possible.
    I saw TL866CS or EZP2013 on the network. I also saw the cheapest, supposedly good CH341A, although I'm not sure either.
    The most expensive of those I gave is probably the first one (about PLN 400) and I would like to fit in this price. If anyone can recommend any of them or anything else at all, I will be grateful.
  • #2 16370801
    E8600
    Help: 529
    Rate: 2520
    I recommend the CH341A usb programmer. Supports a lot of different memory in laptops you are unlikely to find some strange bios that require a programmer with the appropriate connector, usually dip8 or so-8. Choosing a BIOS Programmer: Comparing TL866CS, EZP2013, and CH341A for Laptop Motherboards
  • #3 16371463
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Thanks for the answer, I meant the same model, but with a different appearance:
    is twice different in price, but something else?
  • #4 16371802
    E8600
    Help: 529
    Rate: 2520
    The difference is that one model has a dip8 adapter, there is no usable difference, only the appearance of another and the price.
  • #5 16373416
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Thank you for your answers ;)
