2004 Ford Transit Connect: Coding a New Central Locking Remote - Step by Step Guide?
orion85 6165 4
  • #1 16376620
    orion85
    Rate: 71
    Today the courier provided me with a new central locking remote for the Ford Transit Connect
    2004
    The old remote control works, but the mount is broken.
    The question for you does someone know how to code a new remote control ???
    In the photos on the right, the original Ford second remote is a replacement from ebay.
    • 2004 Ford Transit Connect: Coding a New Central Locking Remote - Step by Step Guide? IMG_2848.JPG (865.85 KB) You must be logged in to download this attachment.
    • 2004 Ford Transit Connect: Coding a New Central Locking Remote - Step by Step Guide? IMG_2849.JPG (954.5 KB) You must be logged in to download this attachment.
  • #2 16376641
    Ringo24
    Help: 76
    Rate: 157
    hello please check 2004 Ford Transit Connect: Coding a New Central Locking Remote - Step by Step Guide?
  • #3 16376978
    orion85
    Rate: 71
    Unfortunately it does not work...
  • #4 16377001
    MobilTruck
    Help: 139
    Rate: 965
    If you do not use it with a broken mounting, replace the electronics with a new one and the problem is gone. The procedure that Ringo24 gave is correct, I did not find another one.
  • #5 16377680
    orion85
    Rate: 71
    I will not translate any electronics, so I bought a new remote control.
    I found the manual on the network, after 30 seconds the remote control was coded :)
