Removing Broken Door Inserts on a 2005 Ford Transit When Key Doesn't Work
anusek 5259 3
  • #1 16217567
    anusek
    Help: 6
    Rate: 150
    Hello, the question as in the subject. The problem is that the inserts are broken and the opening does not work, and to remove it you have to turn the key towards the opening and push the pin. Does anyone have a good patent on how to remove this insert when the key does not work?
  • #2 16742728
    autoas
    Help: 571
    Rate: 3924
    You coped .... maybe you can tell me how to take it out
  • #3 16742735
    anusek
    Help: 6
    Rate: 150
    He removes the lock that is inside the door (such a sheet), you put the key in the cylinder in the door and turn it (I don't remember which way).
  • #4 16742893
    autoas
    Help: 571
    Rate: 3924
    It's just that I don't twist ...... I had to drill and destroy, I just took it out ... but thanks ....
