2004 Nissan Micra 1.2 [K12] - Persistent Humming Noise Despite Bearing Replacement: Joint Issue?
oskar75 5814 6
  • #1 16582006
    oskar75
    The car is a 2004 Nissan Micra 1.2, a 3 door model.
    130,000 Km driven, First owner.
    A car used for everyday driving around the city. No jerking, no smoking, etc.
    Due to the noise, the front bearings were replaced, but the noise did not stop.
    When driving straight ahead, it makes noise, when turning right, it makes a lot of noise, when turning left, silence.
    Having these symptoms, I replaced the bearings, just in case, in both wheels, now I wonder if this noise is not the left joint?
    The driveshaft has no play, it is stiff. Despite replacing the bearings, the sound is like the movie.
  • #2 16582044
    marci4
    Help: 169
    Rate: 177
    And the bearings on the back? Are you sure the noise is coming from the front? Rear wheel bearings wear very often on these Micras.
  • #3 16582116
    oskar75
    The back was made not so long ago.
    What you feel is that at 80 km / h the vibrations in the cabin, while above 120 km / h the noise calms down. It is audible, but there is no hum and vibration.
    There is silence when turning left, straight ahead and when turning right, howls. This misled me because I thought it was the placenta, at least until now such symptoms have always suggested it. As you can see in the video from the link howls.
    I think tomorrow I will use a dictaphone and mount a microphone near the wheels and joints to record the noise while driving and diagnose where it comes from ...
  • #4 16718706
    bobi1326
    Level 19  
    Help: 14
    Rate: 21
    Hello. Was it possible to diagnose the fault! For me, the symptoms are identical, only the noise stops when turning right, and is present when driving straight and turning left.
    Thanks in advance for your answer.
  • #5 16719173
    milejow
    Help: 1563
    Rate: 5149
    Raise the back (front too) and spin the wheels, whichever hoot has a broken bearing.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #6 16719216
    jarek225
    Help: 64
    Rate: 221
    I had the same case, check all the bearings again. 90% of them are one of the bearings, in my case it was the left rear and you would be betting the right rear.
  • #7 16719407
    7hebill
    Rate: 42
    Or you pick up the wheel, grab the wheel, one on twelve, the other on six o'clock and how you feel that summer is vertical, this bearing :) there should be no vertical slack; p
    of course, this is just additional diagnostics
    on the articulation, you turn to the maximum in one side and you move harder, which is also strange because the articulations rather backside seem to hum on the straight wheels; p
    anyway, if you do not replace it yourself (manually), the mechanic will tell you what exactly and replace it ;) if you have a good mechanic there in PL; p
The discussion revolves around a persistent humming noise in a 2004 Nissan Micra 1.2, despite the replacement of front wheel bearings. The user describes the noise as present when driving straight and turning right, while silence occurs when turning left. Suggestions from other users include checking rear wheel bearings, performing additional diagnostics by spinning the wheels, and examining the left joint for potential issues. The user plans to record the noise for further analysis to pinpoint the source of the problem.
